Results 1 to 9 of 9
Thread: SLAM - salt water pool
    It looks like i have a sever algae problem in opening my salt water pool. I opened it a couple weeks ago and it has been cold and rainy ever since. I opened the auto cover yesterday and the slopes are covered with a brown something. If i brush it it looks like a white slime floating. I'm getting ready to start the slam process but have a couple questions.
    1) Is it any different with a salt water pool vs chlorine? I had a chlorine pool before and did the process a couple times. Just making sure there isn't anything i need to watch for with the salt water.
    2) should i turn the salt generator off?
    3) should i brush the algae off the bottom to keep it stirred up and filtering?
    4) should i vacuum to waste instead of letting it filter it out.
    Thanks for any help!
    Jeremiah Hough
    22,000 gallon, vinyl liner, chlorine, with auto cover
    Jun 2014
    17,340
    Re: SLAM - salt water pool
    Good morning! I'll get right to your questions:
    1 - No. Just ensure your SLAM FC level is correct based on your current CYA. Make sure to test CYA and pH before beginning. PH should be about 7.2-7.4.
    2 - Yes; use just regular bleach
    3 - Absolutely. Keep that stuff moving so it can get to the filter
    4 - You certainly can for bulk junk. Might be good in the beginning. But dead algae will eventually go to the filter. Remember numerous backwashes and filter to waste can lower levels (CYA, FC. etc); so follow-up periodically.
    Hope that helps.
    Awesome. Thanks for the quick response. Does that sound like algae to you? Water is clear. The bottom is just covered.
    Jeremiah Hough
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    20,311
    Quote Originally Posted by miahhough View Post
    The "white slime floating" would be enough for me to start a SLAM. If it's not algae, it'll clear up really fast and pass the OCLT in no time.
    domct203's Avatar
    Jun 2015
    CT
    3,900
    ..... Is it any different with a salt water pool vs chlorine? I had a chlorine pool before and did the process a couple times. Just making sure there isn't anything i need to watch for with the salt water.
    If you are using a SWG you have a chlorine pool. Salt is not a sanitizer. The SWG creates the chlorine from the salt instead of you adding it manually.
    If you have simply added salt to your pool for the 'feel' (no SWG), then how do you currently sanitize the pool?
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    Quote Originally Posted by domct203 View Post
    sorry, should have been more specific. i do have a SWG. i understand the SWG creates the cholorine. I just wasn't sure if there was anything different about SLAMing since i have the SWG. I didn't want to mess up any of my equipment.
    Jeremiah Hough
    Here is what I'm getting off the bottom of the pool. Algae?
    Jeremiah Hough
    Ever seen this? Algae?
    Jeremiah Hough
    Jun 2014
    17,340
    From my view, I'm not sure if that is organic related or perhaps calcium related. You have a vinyl pool so you normally don't worry about CH, but it gets really high and pH is off, CH can do some weird things in the water. Also, if you ever added any winterization or other supplemental products to the water that could be it. You have an SWG, and sometimes the initial start of the SWG can cause abrupt chemical changes between products,
