Results 1 to 12 of 12
Thread: Check for metal sequestrant
    Nov 2014
    United Kingdom
    226
    Hi All
    After completing an AA treatment, adding metal sequestrant, bringing chlorine up to correct level and balancing
    Is there a test to check the amount of sequestrant in the water or should it just be used periodicaly
    10,000 gallons inground Leisure fibreglass pool, Hayward powerline pump, Quality120 glass media filter, 27kw output air source heat pump and thermal cover.
    Retractable cover with Polycarbonate roof and glass side for all year round use. K-2006C test kit and Speed stir
    30,950
    Re: Check for metal sequestrant
    That's a good point.....there is no test for it so you will have to intuit when it has grown weak enough that you need another dose.
    Nov 2014
    United Kingdom
    226
    Thanks for the reply
    Is the only way we lose it by backwashing or does it break down
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Chlorine breaks it down.
    Nov 2014
    United Kingdom
    226
    That's a bit of a rough deal not knowing when to top up
    DFW, TX
    24,974
    There are usually subtle signs of staining or greenish tint to the water. Plastic parts, like skimmers, usually turn a little brown first. When you start to notice that an early dose of sequestrant will usually lift the stains so you don't have to keep doing AA treatments.
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,316
    As it turns out, depending on the product you use, there is a test. Here is a link you can look at: http://jacksmagic.com/product/sequest-test-kit/
    Bob - INTEX 12x24 owner (not setup yet), 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    DFW, TX
    24,974
    Hey, look at that. Not cheap, but good find.
    JoyfulNoise's Avatar
    May 2015
    14,085
    Taylor has a test kit for various phosphonate based sequestrants. The multiplication factor (ppm's per drop) changes based on the type of sequestrant (HEDP, ATMP, etc). But the kits are expensive, well over $100.
    See here - Welcome to Taylor Technologies
    Matt
    Nov 2014
    United Kingdom
    226
    I'm based in the UK and i've been using LO-Chlor No More Metal
    I'm not sure of what composition it is
    They say it can be filtered out
    May 2015
    14,085
    Quote Originally Posted by denniswiseman View Post
    According to this website - http://www.ukpoolstore.co.uk/acatalo...-Metal-SDS.pdf
    It's HEDP. So one of those test kits would work if you wanted to spend lots quid on it!
    Matt
    Nov 2014
    United Kingdom
    226
    Thanks for that
    The problem is shipping (if you can find someone) and 20% VAT
    I might have a word with LO-Chlor and see if they have a test
