Thread: Diverter valve makes noises; filter psi rising/flow decrease
    Two separate issues, I don't think they're related.
    My diverter valve makes a loud noise like it's a clogged vacuum. This only happens in the "filter" position (it has 6 positions). The handle also visibly moves up and down on its on depending on what speed I have the pump on. It also leaks out the waste line in the filter position. Do I just need to replace some pieces? I'm not sure on the model, a side sticker was pulled off. The only number I see is SM10-2D.E. Pentair.
    The filter (DE) slowly gains pressure while filtering, and eventually there is little to no flow coming out the returns. The pump will lose prime as well, it takes a while. I assume it's just fighting algae and getting clogged (the water's a bit cloudy), and this is a pretty common complaint on here, but I'm just mentioning it in case it has anything to do with the diverter valve. Any input would be grrr8.
    Inground 20x40x3-6'
    DE filter
    Intelliflo pump (it's a beautiful thing)
    Chlorinator (stopped using due to my old DE-grids shredding and constantly clogging it up((didn't know what it was at first)), but may start using salt again now that the problem has been fixed)
    Intex 24' by 52" round metal frame vinyl holding about 12,500 gals.
    Krystal clear Model 633 Filter Pump Cartridge 1/2 HP Pump
    TF Test Kit (Thanks Dave) Located Central Texas Coast
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    1,375
    Re: Diverter valve makes noises; filter psi rising/flow decrease
    I think you're probably right on both counts. The valve should be disassembled and inspected. The filter is filtering out whatever is clouding the water.
    I believe this is your valve.
    Thanks. Hard to tell from that view but that's probably it.
