Results 1 to 9 of 9
Thread: is it ok to partially open a pool and leave it uncovered overnight?
    Apr 2017
    Upstate NY
    145
    Question is it ok to partially open a pool and leave it uncovered overnight?
    Hi, total newbie here, just bought a home with a pool back in September.
    I just got our new Hayward S244S filter (in my sig) installed today, took the cover off, there's some algae in the pool and debris like some small leaves but nothing too crazy... got the pump and filter all hooked up but the one thing I was missing was a screw-on clamp for the backwash/waste roll-out hose. So I had to run to Home Depot to get one but when I got home it was dark.
    So my question is: is it okay to just leave the pool as-is, uncovered tonight and try getting the pump and filter going tomorrow morning?
    -Gary
    SLAM Chlorine/CYA Chart PoolMath Pool Chemicals
    20,000gal IG Vinyl Pool, Village water
    Hayward S244S Pro 24-Inch Side-Mount 1.5" Sand Filter w/ Sidley Sand
    Pentair SuperFlo SF-N1-1A/340038 1.0 HP Pump
    TF-100 Test Kit w/ SpeedStir
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    10,152
    Re: is it ok to partially open a pool and leave it uncovered overnight?
    You'll be just fine.
    Apr 2017
    Upstate NY
    145
    Thanks, I thought so, but just wanted someone to tell me "it's going to be okay", lol!
    In other news my TF-100 is supposed to arrive tomorrow!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    20,299
    I hope so! My cover disintegrated and I threw it out a couple years ago. My pool sits open 365 days a year.
    Apr 2017
    Upstate NY
    145
    Haha! I dunno if that would fly in upstate NY. (But maybe? As long as the gizmo is in?)
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    33,917
    Gary, we are starting to lean towards telling above ground pool owners in the ice/snow states to NOT use covers as we are seeing quite a few walls buckle from the weight of the cover and ice/snow on it. If you do what needed to do to the equipment then you can leave it open BUT the leaves and such do need to be thought about. How to keep them out of the pool??
    Kim
    Apr 2017
    Upstate NY
    145
    Ah-ha! That would make sense for above-ground pools, yeah.
    Jul 2012
    Tallahassee, FL
    33,917
    SO if an above ground pool can be left open................You have to weigh the pros and cons of each way.
    Kim
    Apr 2017
    Upstate NY
    145
    Right on. I have an in-ground pool so it doesn't apply to me, but still interesting to know.
