Results 1 to 11 of 11
Thread: Stenner Pump Chlorine DIY Question
    el duderino's Avatar
    Jun 2008
    Austin, TX
    118
    I just finished wiring up my Stenner pump. Like most guys, I read the directions after I mounted the pump to my brick wall. I mounted the pump for convenience, and it turns out it is slightly below the top of the tank (which most likely won't be filled). With the back flow preventer in the pump, is this an issue? I can fairly easily move it's location. I'll try to add some pics once I can.
    Our pool- (Completed March 2009)
    20k gallons, 38x15 Free Form Gunite (3.5'-8'), 26' Negative Edge and 7' Negative Edge spa with blower, Midnight Blue Diamondbrite, AquaLogic PS-8 control, Goldline Salt Chlorine Generator, 2x1.5hp Pentair 2 speed pumps, Pentair DE Filter, Pentair 400k BTU Heater, and BlackMaxPolaris 280 w/ Hayward booster pump, Pentair Prowler 920, DIY Stenner Chlorinator
    RonsPlc's Avatar
    May 2015
    Gaylesville, AL
    589
    Re: Stenner Pump Chlorine DIY Question
    It should work fine. I have mine mounted about 2 feet above the top of a 55gal drum that I keep my chlorine in, and it works like a charm.
    14600 gal Intex 24' Round 52" deep AG Pool (Heavily Modified)
    200lb sand filter w/2 speed 1.5/0.5hp pump
    Stenner 45MHP10 Liquid Chlorine (well... bleach) Injector. Borates added.
    K-2006 test kit w/Speedstir
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    22,701
    As Ron said, it won't be a problem. The only reason to mount it above the vessel is to provide a drain from the pump head back into the drum in case of a pump tube rupture. With bleach, it isn't much of a concern if you spill a little. I doubt most pool owners even bother with the pump head drain.
    Mar 2013
    CT
    363
    What did you use to mount the pump to the brick?
    16 x 32 In-Ground vinyl, 21,000 Gallons, Hayward Cartridge Filter, Hayward Tiger Shark robotic cleaner, Taylor K-2006 Test Kit
    Jun 2013
    Freehold NJ
    137
    el,
    Why did you get rid of the Goldline salt generator?
    38,000 gallon vinyl liner, True "L", Sand Filter, Hayward Heater, Diving Board
    GDN's Avatar
    Oct 2016
    Dallas, TX
    308
    Quote Originally Posted by dschribs View Post
    I mounted mine to brick and just used a concrete drill bit and a couple of blue Tapcon screws. Took two minutes.
    Greg -
    11K gal, IG Pebble Sheen (Aqua Blue) with sun ledge and attached spa, Pentair Intelliflow 3050 VS/SVRS (3HP), Pentair ET 8 with Screen Logic, Pentair Racer with 3/4 HP booster pump, 400KBTU Pentair Mastertemp, Pentair 60 sq ft DE filter, J&J Intellibrite LED in spa, Zodiac Nature 2 (not used), Stenner pump/liquid Chlorine, build completed in August 2015
    Jun 2008
    Austin, TX
    118
    I used Red Head sleeve anchors and a 1/4" masonry bit.
    Jun 2008
    Austin, TX
    118
    Quote Originally Posted by JoeRJGR View Post
    el,
    The salt was destroying our stone decking and rusting everything in sight. I loved the convenience and water feel but all the stone pitting was too much to handle.
    22,701
    I used Tapcon's to mount my Stenner also. They work great in the mortar joints.
    Jun 2013
    Freehold NJ
    137
    wow...thats disturbing...
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,892
    Not necessarily a problem you will deal with in NJ. The issues with natural stone seem to be concentrated in the southwest US, mainly Texas
    Support the site
