Results 1 to 7 of 7
Thread: Skimmer suction vac?
    Sep 2016
    Katonah NY
    172
    Hi,
    Can someone recommend a good pool vac to use with my skimmer? I have a pole & 40' 1.5 hose, just need something to clean with. I have a polaris 280 which runs around but I need something for trouble areas.
    Rich
    40k IG Gunite pool (47x21), Jandy iQ904-PS, Pentair 011018 VS Pump, Pentair 180009 FNS Plus Filter, Pentair 261152 Multiport
    Stenner Liquid Chlorine Dispenser - 30 gallon tank, Zodiac PB4-60 Polaris Booster Pump, Polaris 280 Pool cleaner
    Pool School + Test Kit + PoolMath = A TROUBLE FREE POOL Become a TFP Supporter!
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    10,155
    Re: Skimmer suction vac?
    Any standard vacuum head for an inground pool I'd think.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    20,301
    I use one that looks like this that I bought at Lowes.
    Sep 2016
    Katonah NY
    172
    I have two skimmers - do i need a 'blank' cover to close off one of the skimmers (I have two)?
    Richard320's Avatar
    Jan 2010
    20,301
    Quote Originally Posted by RichTJ99 View Post
    If they're teed with no individual valves, yes. It's much easier to pull water through the skimmer than through a lengthy hose. It doesn't have to be fancy. A rubber ball, a rock, whatever. Just be sure it won't break and/or get sucked down. You can develop a lot of suction!
    Sep 2016
    Katonah NY
    172
    So I think this is how my setup works (not entirely sure):
    Pipes: http://i.imgur.com/KcOp28C.jpg
    Skimmers: http://i.imgur.com/fo4OIg4.jpg
    So if I turn the spa skimmer off, the deep skimmer off, then use a ball in the far skimmer, the skimmer that has the suction for the vacuum should work very well?
    Do I need to worry about it vacuuming my skin off if I happen touch that area by accident?
    Richard320's Avatar
    Jan 2010
    20,301
    More likely is that the head will get stuck on the pool floor. If that happens, just crack the spa or main drain a little so you have enough suction to vacuum without getting stuck constantly.
