Results 1 to 8 of 8
Thread: Pool rake for plaster
    May 2016
    Westchester NY
    9
    I was given a pool rake that will not slide easily on my pool's plaster finish. The rake has a rubber-ish leading edge. So it's like trying to push a piece of rubber along asphalt--impossible to do smoothly. I thought maybe the rake I was given might be best suited for a smooth vinyl, but Googling hasn't really confirmed this.
    Can you recommend a pool rake that would be appropriate for a sort-of rough plaster pool?
    In-ground, 18' x 26', 33,000gal, raypack propane heater, Hayward S244T sand filter, Hayward SuperPump 1.0hp, 1-1/2" typical plumbing
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Re: Pool rake for plaster
    Mine works well on the pebble. It has an aluminum frame and a hard plastic leading edge. Sort of like this, Pool Pals Pro Stinger Leaf Rake LN4000
    Jan 2017
    Orlando/FL
    124
    You should be pulling the rake, not pushing it.
    20K gal In-ground pool with raised Spa overflowing into pool; two Jandy Sheer Descent waterfalls; Pentair IntelliTouch i7+3, IntelliChlor, IntelliPH, 3 SAM/SAL lights, Pentair FNS60Plus filter, two 1.0 HP WhiperFlow pumps, Jandy/Compool auto-valves, RayPak Heatpump, RayPak 406A LP spa heater, Polaris 360 PS Cleaner. Patio and deck lighting by Volt; Volt 600W landscaping transformer; Webber grilling station
    DFW, TX
    24,974
    Interesting, I push mine too.
    30,950
    How do you pull a leaf lake? I can't picture that?
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,764
    Bumkin may be thinking pulling on the surface, but this is pushing or scooping up debris on the floor of the pool with the net.
    Factory Warranty Station for:
    Jandy/Zodiac, Pentair, Sta-Rite, Raypak (Rheem, Rudd), Polaris,
    Jan 2017
    Orlando/FL
    124
    I was making a not-so-funny joke - thinking of how a garden rake is used in dirt. Sounded funny in my head. Sorry.
    DFW, TX
    24,974
    LOL! OK, I'll laugh with you on that.
