Thread: Opened to wrinkles in liner
    Jun 2015
    Ottawa/Ontario
    357
    Any thoughts on how to fix wrinkles? One source said drain pool, another said partial drain and use a toilet plunger...a third source said to pump water to other side of pool, and float liner..that seems ludicrous to me, and could cause more damage.
    I am not sure where to start, but I really don't want to drain...
    20000 gallon, Vinyl liner IG, SWG, Sand Filter, Hayward 1/2HP + Lorentz direct solsr PV pump
    Apr 2017
    Upstate NY
    145
    Re: Opened to wrinkles in liner
    I'm in the same boat as you - took the cover off today and noticed some wrinkles in the shallow end. We just moved into this house in September so I'm not sure if they were there or not.
    They don't seem to be that large, so I'm also wondering if I can just live with then for now.
    SLAM Chlorine/CYA Chart PoolMath Pool Chemicals
    20,000gal IG Vinyl Pool, Village water
    Hayward S244S Pro 24-Inch Side-Mount 1.5" Sand Filter w/ Sidley Sand
    Pentair SuperFlo SF-N1-1A/340038 1.0 HP Pump
    TF-100 Test Kit w/ SpeedStir
    Jun 2015
    Ottawa/Ontario
    357
    Read in another post that gentle brushing when there is a high water table can help get the wrinkles out...
    18000 IG, SWG, 1/2 HP Tri Star + Solar PV direct DC Lorentz pump, Sand filtrt
    30,941
    Those wrinkles will be almost impossible to move until the water table around the outside of the pool rises high enough (again) to float the liner.
    When that happens you can gently us a push broom and carefully push the liner up against the frame. Youi may not get them all but folks report good success if you are patient.
    It's a big job but the real answer is to install 1 or 2 or 3 wellpoints around your pool so the ground water can be drawn away with a submersible pump.
