Thread: Floating liner question
    Jun 2014
    Rogers, AR
    444
    We got hit with massive rain for the last week and my liner floated.
    I have been gently and slowly coaxing it back into place all morning. The shallow end is back under water but still floating. Can I turn the pump back on to start filtering or should I wait? I have everywhere else back into place but still has some water under it and I can still push it around with my brush.
    16x32 IG rectangular 21,800k new vinyl liner 2014, Triton II TR 50 sand Filter, Pentair 3/4 hsp whisperflow pump, 3 returns, TF100 test kit w/speedstir. Maytronics s300i robot, Raypak 406k Heater.
    madyogi's Avatar
    Jun 2016
    Little Rock, AR
    185
    Re: Floating liner question
    I've had a similar issue down here in Little Rock. I still have a fair amount of bubbling, but my liner is staying in place for the most part. This is our first spring with a pool, so I can't offer much advice, but I can certainly empathize.
    How's your situation this evening?
    Philip
    20,000 Gal IGP, Vinyl Liner, 1.5 HP Century Pump, Hayward S244T Sand Filter
    Polaris 360 Pressure Vacuum, 3 Wall Returns and 2 on Stairs, 1 Skimmer and 1 Main Drain
    Borates in the Water, Duda Bags and DE as Needed to Augment Filtration
    Taylor K-2006 Test Kit
    Apr 2013
    Sacramento, CA
    2,769
    Yes you can start filtering again. Give it 30 minutes and see if there is any movement.
    You need to strongly consider a french drain or dry wells to deal with the water. If it happens once it will again.
    Jun 2014
    Rogers, AR
    444
    Quote Originally Posted by gwegan View Post
    I have everything back in place and the filter has been running. We have been hit with torrential rain. The area has been declared a disaster area.
