Results 1 to 7 of 7
Thread: Anyway to keep PH Down
    Jan 2017
    PALM BEACH GARDENS, FL
    107
    Thanks to TFP, I think I got this chemistry thing down. But always having to add Muritac Acid weekly to keep PH Down. I dont really run waterfalls or bubblers to try and keep it down but it always climbs to 8.2 to 8.4 Any advice.
    My numbers below are pretty consisitne with my test (I do realize im running a little high on chliorine)
    CL-5
    PH-8.2
    TA-70
    CH-400
    Salt - 3200
    thank you
    Pool Size: 17,504 gallons.
    In ground gunnite plaster pool (Florida Gem Stucco)
    Filter Hayward Cartridge C200SHayward Ecostar SP3400VSP variable speed pump.
    Pool Install December 2016 Blue Essence SALT system
    (2) 48" Sheer Descent Waterfalls and (1) bubbler on small deck
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    20,299
    Re: Anyway to keep PH Down
    Target a lower pH. Shoot for 7.2. That will buy you a little extra time and also drive down TA, which should slow down the pH rise. If your refill water is high in TA or pH, you're just going to have to accept the reality that acid is a way of life. That's my situation, and I keep my TA around 60.
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    9,261
    GTP,
    I noticed that you did not report your CYA..
    If really low this will make your SWCG work harder (longer) and that will help push your pH up.
    What is your SWCG% and how long do you normally run your pump?
    And.. an FC of 5 is not at all high for a saltwater pool.
    Jan 2017
    107
    I usuallly run my pump 4 hrs in morning and 4 hrs in late afternoon. The SWG percentage is usually at 50 but sometimes dial back to 40%.
    My CYA is about 60
    thanks
    Tim
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    10,152
    Just so you know-----------running those will RAISE PH. Or maybe you know that and it is why you are NOT running them.
    Jan 2017
    107
    yes i try not to run them as it raised PH
    Jul 2014
    Bedford, TX
    9,261
    Tim,
    If you increase your CYA to 80 you will be able to run your SWCG at a lower percentage..
