n240sxguy
Re: SmartPool/Fafco Solar panel install.. questions and build notes
That's the part where I was saying I would probably put a ball valve on each side of mine with a T and a drain valve coming straight out. That way I can isolate it at the pool side, open the drains to drain as much as possible, then close the valves going up to the panels and blow out the underground lines through the already open drains. They don't have o-rings on those fittings because they are NPT(national pipe thread) fittings; meaning the thread pitch changes along the way causing a friction fit that seals it.
