Results 1 to 8 of 8
Thread: Sand filter valve
    Jun 2016
    Alton , il
    10
    Sand filter valve
    I'm wanting to replace my filter valve , it doesn't close properly and is hard to turn but not sure of the type and size I need can anyone help me out
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    20,302
    Re: Sand filter valve
    The brand is Waterway. It should be easy to find what you want by googling now.
    http://www.waterwayplastics.com/manu...-0118.0209.pdf
    Jun 2016
    Alton , il
    10
    Besides the valve assembly what else would I need ?
    Richard320's Avatar
    Jan 2010
    20,302
    Quote Originally Posted by Jmh618 View Post
    Make sure it comes with any O-rings you might need. And some pool lube for those O-rings.
    Jun 2016
    Alton , il
    10
    Thanks sir
    Jun 2016
    Alton , il
    10
    Found one on Amazon any clue how much sand I need to use in it . Not finding much about the millennium
    Richard320's Avatar
    Jan 2010
    20,302
    I'd check each and every manual on this list and see what they all say or if one in particular is your exact model Instruction Manuals
    22,703
    That looks like a rebranded Waterway Carefree Deluxe Sand Filter. That's a 19" so it takes 200# of filter sand.
    Why are you replacing the sand?
    Also, you can buy parts for those valves and just rebuild yours.
