Thread: Sight Glass has green algae visible
    Sep 2016
    Dallas, Texas
    188
    Hello TFP friends!
    First let me say again what a great wealth of knowledge for pool owners. Many kudos to those that created it and keep it running!
    I've just noticed for the first time that there is algae visible in the backwash sight glass. Is this normal? How should i address it?
    Thanks!
    Matt- IG gunite pool and spa built Summer 2016: 32' x 20' overall with two 4' x 8' tanning ledges. 6'x6' attached spa with spillover. Depth 3' to 5' to 4'. 16.4K gal. Lueders Limestone retaining wall and coping. Equip: Pentair SVRS vari. speed pump. Pentair 60 sq. ft. DE filter. Pentair Kreepy Crawly Plat. cleaner. Pentair MasterTemp 400,000 BTU NG heater. 1.5 HP spa air blower. Nature2 Sanitizer. Taylor K-206C. My 2016 Build
    40,855
    Re: Sight Glass has green algae visible
    Happens in mine too, it should only see what when backwashing, then the water is trapped and algae can grow. Just unscrew it and clean it out of it bothers you.
    I think it should eventually dry out. If it does not, then the valve could be leaking a little to backwash. Pull the vial off and leave it off and see if there remains water in there.
