Thread: Pool slide inground pool
    Aug 2016
    Ruther Glen, va
    9
    Does anyone know what would cause my slide not to have enough pressure to push water up slide? I'm wondering if I replaced the pump with the wrong size. It used to work with old pump.
    Inground 35,900 gal, Hayward sand filter, Hayward 1.5 HP pump, well water, vinyl liner, test kit is TF-2006
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    33,941
    Re: Pool slide inground pool
    Do you still have the old pump? Do you have ANY idea what size your old pump was?
    Kim
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    9,277
    K,
    Normally there is some type of adjustment valve in the line going to the slide..
    You may just need to adjust it.
    Aug 2016
    Ruther Glen, va
    9
    where would the adjustment valve be? The only thing I ever did was open a gate valve and It worked. I trashed my old pump so I don't know the hp power but I thought I bought the exact replacement. I did however block one of the return jets and it worked fine. However I have never had to do that before.
    Oct 2013
    Iowa
    89
    We don't have any adjustment on our slide, I've often wondered if it was luck, skill, experience, or a little of all three that the builder got the pressure just right for the slide. When the slide stops working for us, it means it is time to backwash the filter. Have you backwashed recently?
    20,000gal in-ground 16x36 sentry pools vinyl liner, Pentair sand filter, Pentair minimax NT heater, auto-cover, Polaris 280 cleaner.
    Sep 2010
    Orange County, CA
    56
    Quote Originally Posted by Klester View Post
    You could have an adjustment valve in multiple locations. For example, my slide has one at the base of the slide and there's another one back by the pool pump. I always leave the one at the base of my slide open and adjust how much water goes to the slide and my deck jets at the pump area.
    Do you know if you have a dedicated pipe to your slide from the pool pump area? Or is it just plumbed in with your return lines?
    Make sure you unblock your return line when not using the slide so your water circulates properly.
    Southern CA 30K gal Pebble Pentair WhisperFlo 1HP 2 speed Hayward DE6020 filter Paramount Debris Canister Goldline/Hayward AquaRite Pro SWG (T-CELL 15) Sense & Dispense (acid) Pentair IntelliBrite 5G and GloBrite Inter-Fab G-Force slide Jandy deck jets Lion head spout Dolphin Premier Cleaner Taylor K-2006 test kit
