Thread: Cutting the Pool Wall...Eeeeekk but did it. Thanks!! and a QUESTION
    PoolMumsy's Avatar
    Apr 2017
    Ft Worth, TX
    36
    Hi There,
    New to TPR, but I'm already a fan!!
    Last summer, it was time to get another Intex Pool. I ordered an 18'x52" online, because it fit the existing pad sight. As many of y'all know from experience, it showed up with the two 1" outlets. Booooo!!
    A big "Thank You" for the advice, instructions, and pictures from the brave and knowledgeable souls who CUT THE POOL WALL before and lived to tell and post about it. As of yesterday, I have successfully cut and converted one 1"outlet with a tubethingy to a 1.5" outlet with a gasket strainer and plunger valve.
    My plan was to convert the other 1"tube outlet as well, and use it for a pool vacuum, but as I read more, I see it's not necessary and have the Intex 2500GPH Pump upgrade and Intex Auto Cleaner on the way. Yay, Amazon Prime!!
    QUESTION: What have y'all done with the other 1"tube outlet?? Ideas? Just seal it off, and how? Thought about adapting for a heater, but I don't need a heater in Texas for summer and take down the pool to use the pad site for a fire pit in the winter.
    Thanks & Blessings, y'all
    Let the pool merriment begin
    Intex Ultra Frame 18' x 52" pool, Intex Krystal Clear 15k SWG, Intex 2500GPH pump , Intex Auto Pool Cleaner
    Previously owned an in-ground gunite pool /hot-tube with a Nascent Oxygen Generation purification system. Frankly, it was the bomb, but grateful for Intex.
    Apr 2013
    Sacramento, CA
    2,769
    Re: Cutting the Pool Wall...Eeeeekk but did it. Thanks!! and a QUESTION
    PoolMumsy's Avatar
    Apr 2017
    Ft Worth, TX
    36
    Thank you. I found the relevant posts
    Aug 2015
    1
    Hello, PoolMumsy!
    Question for you (I am preparing to cut my 12' round intex pool to accommodate the new sand filter) Did you do the cutting while the pool was set-up? Or before it was full of water? I'm just wondering if one way or the other is better.
    If anyone reading this has thoughts, I'd love to hear them!
    Intex UltraFrame 12x36 pool with stock pump & filter (hoping to upgrade this season to a sand filter and possibly SWG)
    chayne's Avatar
    May 2016
    Somewhere Around The Red River, Texas
    419
    i filled mine up to about 6 inches from where i wanted to put my skimmer. i wanted to let the water stretch out the liner before i cut it. i had no problems at all with the cut.
    Charles
    Coleman 16'x48"
    Intex 16" pump & Sand filter, Intex Robot Vacuum
    Hayward Wide Mouth Skimmer
    TF-100 Test Kit Magnetic Speed Stirer
    PoolMumsy's Avatar
    Apr 2017
    Ft Worth, TX
    36
    Hi there, PachaMama
    Sorry for the delay in reply. I havent figured out notification settings yet.
    Actually, I did both with the pool full to just below the valves. the second one was done a few days after the first and I had raised it to that level. It seemed easier, but honestly it could have just been that I was more relaxed.
    Hope things go well for you!!
    blessings from Texas
