Thread: All the info for an AGP heater. Natural Gas
    Apr 2015
    Waterford, MI
    137
    We are considering a heater for out AGP. I want to plan it and price it out to see if its in a budget we can afford.
    Stats on the pool are in my signature.We are in Michigan. The has meter is currently 175 cubic ft. per hour. Nothing in my home is gas except the furnace and the home is small. The distance from the meter to the pool is 140'
    I understand many people say go with a 400 BTU heater (Looking on Craiglist all the used stuff only seems to be only 150 BTU). I also understand I will most likely need to call my gas company and get a larger meter.
    My questions are ...
    1. What size heater should I go with?
    2. What size underground gas line do I run?
    3. What size gas meter do I need? (
    4. What else am I forgetting and do I need to know.
    Thanks!
    Michigan - 24'x54" AG, approx 15,000g, 2 center drains, Cartridge filter, Aqua Pro 2hp, 2 speed pump 3.5a@1725w / 10.5a@3450w, AquaCal TropiCal T90 heat pump, Hayward Salt & Swim SWG, Poolskim, Aquabot Rover Jr.
    Apr 2015
    Waterford, MI
    137
    Re: All the info for an AGP heater. Natural Gas
    I found this chart.
    Looks like at 150' I get, 324 BTU with 1 1/4" pipe
    or
    486 BTU with 1 1/2" pipe.
    I found 1 1/4" pipe very easily. 1 1/2" seems to be much harder to find.
    Cost is about $150 for the 1 1/4" pipe and another $250 for a couple risers. Misc fittings is probably another $50 in fittings. Reamer tool, probably another $50.
    Sounds like $500 in material, plus the heater.
    CJadamec's Avatar
    Apr 2016
    Quaker Hill, CT
    2,192
    You probably don't need a 400k if a 1.25 inch pipe gets you over 300k that size heater is plenty for you pool.
    I would suggest contacting a gas company they will be able to run flexible stainless pipe for you. They will also know all the local codes and permits required​. I'm all for DIY but you need to get it right the first time with gas lines.
    Chuck-
    15x30 AG, Pentair Superflo VS, 19" sand filter, TF-100 test kit
    Aqua Comfort ACT750 heat pump / 6x20 ground mount solar panel / DIY automation
    Photos of 2016 Build, Inside Your Breaker Panel, Free Copy of 2017 NEC code
    TFP is AD Free and is funded solely by member support click here to help
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,838
    Trick, I am in Michigan and am running a 24,000 gal pool on a 266 BTU Raypak, which will get me a little over a degree an hour.
    I chose this size to avoid a meter upgrade and need to upsize my long run which also goes through my large, attached office that I didn't want to disrupt.
    While its important not to under-feed a gas boiler, I've not had any trouble at all even running simultaneous with the house boiler and various NG appliances (I operate in he winter with an air-inflated dome, which is how I know this )
    I'm thinking that if a 266 btu handles my pool IN WINTER, you'd be all set, and likely get more like 2+ degrees an hour or more, with a 266
    In my pool, with efficiency in the Calc, I use about 2 CCF an hour when heating, which at our rate with all taxes and surcharges in, is about $1.54. Remember that a 400k btu unit will use twice that an hour. While sometimes it can be more efficient to heat fast, frequent cycles of dramatic fast heating can also end up being more expensive that a "dedicated heat retention plan" with scheduled, incremental warm ups. Its worth experimenting to see what works in your situation.
    Before getting the dome, I ran 24/7 to 88 degrees May through mid-Oct, uncovered but using Cover Free to reduce evaporation. I did discover that in my case, wanting warm morning water for a swim, Thermostatting cost about the same as run-ups, making Thermostatting preferable because the pool was always the temp I wanted.
    Since getting the winter dome this year and being highly motivated to keep my energy costs within a comfortable realm, I'm actually keeping 95 degree water 24/7 for less than my previous May bill most months (January excepted.)
    So make sure you have a good solar cover for our dramatically cooler nights, and or use an evaporate barrier like Cover Free to keep you NG bill down
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
    Exton, PA
    250
    You forgot about where to place the heater. I'm having one installed and the town has no code. They said refer to the manufacture's manual.
    From Raypak: For windows and doors, 4 feet seems like the magic number. Air intake for the home is 10 feet.
    • For U.S. installations, the point from where the flue
    products exit the heater must be a minimum of 4 ft
    (1.2m) below, 4 ft (1.2m) horizontally from, or 1 ft
    (0.3m) above any door, window or gravity inlet into
    any building. The top surface of the heater shall be at
    least 3 ft (0.9m) above any forced air inlet, or intake
    ducts located within 10 ft (3m) horizontally. See
    18' AG pool, 7,646 gallons, Sun from 11:30AM-2PM.
    Pentair Dynamo 1hp pump, Intermatic Timer (6/17)
    Pentair Sand dollar filter - 100lbs, 35gpm
    Pentair Lil' Shark cleaner, TF-100 Kit
    Raypak 206A 200K, BTU gas (6/17)
