Results 1 to 8 of 8
Thread: CYA Reducer
    Apr 2017
    Dallas, tx
    32
    CYA Reducer
    What does everyone think of the newer CYA reducer that Leslie's Pool Supplies carries?
    Ashley
    20,000 gallon IG pool
    DE Filter
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    9,247
    Re: CYA Reducer
    Tink,
    We all think that Leslie's should carry it... to the dump.
    I'm not sure if anyone here has used it successfully, but there are several posts about it not working.
    I have a friend who tried it and it was less than successful and I believe he was actually duped into using a second dose..
    Let's see if we get anyone with a positive post to chime in...
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,892
    Re: CYA Reducer
    Jim has covered it well. Several members tried it with minimal or no results. The manufacturer even participated here on the forum for a short time trying to work with members to get positive results. When no positive results were obtained they stopped participating.
    We have had several folks join the forum, say the stuff is the best thing since sliced white bread and then never participate again. I don't want to accuse anyone of being a shill, but these type of "reviews" are suspect at best.
    We base our pool care system on accurate testing and only adding what the pool needs, when it needs it. To do that you need your own accurate test kit. Anyone who posts reviews of the product using only pool store testing (we have had a couple) are ignored entirely.
    So, with that being said our advice is still to do a water exchange or a Reverse Osmosis treatment to reduce CYA. Water replacement is almost always more economical than RO.
    Support the site
    Donldson's Avatar
    NW Ohio
    3,209
    Re: CYA Reducer
    People typically have 2 options to reducing their CYA (RO is not available in most areas):
    1. Perform partial water replacement.
    Or:
    2. Add CYA reducer. Spend a week trying to let it work. Try another bag. Spend another week trying to let it work. Perform partial water replacement. SLAM because the pool turned green due to keeping FC low per CYA reducer instructions.
    I have a preference for option 1 myself.
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath
    Jul 2014
    Bedford, TX
    9,247
    Re: CYA Reducer
    Tink,
    I live in the DFW area and can fill my whole 17K pool for $50..
    Replacing the water seems more economical to me..
    Apr 2017
    Dallas, tx
    32
    Re: CYA Reducer
    How do I know how much of my water needs to be replaced?
    May 2014
    Franklin, NC
    9,892
    Re: CYA Reducer
    Use PoolMath to make the calculation. Just enter the current CYA in the "Now" column and what you want it to be in the "Goal" column and the box to the right will tell you how much water to replace as a %.
    Support the site
    Jul 2014
    Bedford, TX
    9,247
    Re: CYA Reducer
    Tink,
    There is no way for any of us to know, because you did not tell us what your current CYA level is...
    You also did not tell us how you are chlorinating your pool, as a SWG pool has different CYA requirements than a non-SWG pool.
