Thread: Hayward flow switch replaced, still no flow
    Apr 2017
    Montreal, Canada
    2
    Unhappy Hayward flow switch replaced, still no flow
    Hi
    Pro-Logic P4 .. I had a cut wire to flow switch and replaced it all together since its from 2009 New GLX-FLO-RP plugged the phone connecor into motherboard jack.. Switch arrows facing a very solid flow... New T15 cell, one year old, clean... Basically all seems clear to go, No leaks, no air.... but I keep getting no-flow system info so chlorinator stays off. Any idea what else I could be looking for
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    9,248
    Re: Hayward flow switch replaced, still no flow
    HJB,
    Welcome to TFP... A Great resource for all pool owners with flow problems...
    I assume you installed the switch in the right direction, but you said "Switch arrows facing a very solid flow" Did you mean they point in the direction of the flow?
    The only two things that effect the flow switch closing are:
    1. The switch itself is defective or installed backwards.
    2. The flow itself is too weak because the filter is dirty or the variable speed pump is set to too low of an RPM.
    Other than that, I'm out of options.
    Let's see if we can get one of our Pro-Logic P4 users to chime in..
    Thanks for posting,
    Apr 2017
    Montreal, Canada
    2
    [Thanks for your answer... Turns out that after calling into Hayward on my second attempt a wise tech told me that the arrows printed on the probe(flow switch) are "sometimes" printed backwards i.e. wrong direction... I turned it 180 degrees and voila! Problem solved!!!
    Thanks for posting,
    Jim R.[/QUOTE]
