Thread: How to lengthen copper bonding wire
    Apr 2016
    Elliottsburg, PA
    7
    We moved our pump further away from the pool and the copper bonding wire does not reach. Is there a right way to add wire to it? What type of wire should be used - #8 bare copper? Thanks!
    12K gal, AG Oceanic, Hayward EC50 1.5hp pump, Hayward DE filter, Installed May 2016, Filled w/ delvd water - supplement w/ well water.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,895
    Re: How to lengthen copper bonding wire
    You want a split bolt connector This is for example only, Granger is very pricey --- Split Bolt Connectors - Wire Connectors - Grainger Industrial Supply
    Support the site
    Apr 2016
    Elliottsburg, PA
    7
    Should I get the bolt in copper as well? Also is the bonding wire #8 copper as I will need more.
    CJadamec's Avatar
    Apr 2016
    Quaker Hill, CT
    2,192
    Unless you are in Canada as they require #6 solid copper bare wire. #8 is fine for us folk south other the northern boarder. The split bolt connectors you get at home Depot or other similar box store are rated for the service you need which is direct burial. There aren't many other options in the split bolt connector product line.
    Chuck-
    15x30 AG, Pentair Superflo VS, 19" sand filter, TF-100 test kit
    Aqua Comfort ACT750 heat pump / 6x20 ground mount solar panel / DIY automation
    Photos of 2016 Build, Inside Your Breaker Panel, Free Copy of 2017 NEC code
    TFP is AD Free and is funded solely by member support click here to help
