Results 1 to 14 of 14
Thread: Opening pool - make sure I am doing this right.
    May 2016
    Pittsburgh/PA
    54
    Person I bought house off of had a crappy pool cover that ripped and eventually fell in. So my pool is yeah green.
    Pump set up. Running.
    Cya 20
    PH 8.6
    TA 65
    FC 0
    Now I assume step one is to fix the PH and the cya to 30.
    Then begin to slam? TA is fine right?
    27' Above Ground Pool.
    Vinyl Liner
    Cartridge Filter
    TAYLOR TECHNOLOGIES INC K-2006 TEST KIT COMP CHLORINE FAS-DPD
    May 2016
    Pittsburgh/PA
    54
    Re: Opening pool - make sure I am doing this right.
    Gonna add 24 oz of muriatic acid and a small amount of stabilizer. Then retest tomorrow. Need to double check if that is too much acid for all at once first from the resources.
    Vinyl Liner
    Cartridge Filter
    Donldson's Avatar
    NW Ohio
    3,217
    If you are getting a CYA reading of 20 I wouldn't worry about a 10 ppm increase, just adjust your pH and get some chlorine in there. The sooner you start SLAMing the sooner you will be finished. Then you can work on fine tuning your CYA level.
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    10,152
    Suggestion--add half that amount of MA, circulate for 30 minutes and test again.
    May 2016
    Pittsburgh/PA
    54
    Well I added an eyeball amount. Is it better to slam with the lower cya before raising it? Seemed like you were suggesting that.
    Vinyl Liner
    Cartridge Filter
    Apr 2010
    East Texas
    10,152
    CYA testing accuracy is within + or - 10ppm.
    May 2016
    Pittsburgh/PA
    54
    I had to use the pool store for the cya cuz I ran out of reagent mid test. The new stuff wont be here for a week or two.
    Vinyl Liner
    Cartridge Filter
    May 2016
    Pittsburgh/PA
    54
    Great... almost out of R0003 now. Ugh... lol
    Vinyl Liner
    Cartridge Filter
    May 2016
    Pittsburgh/PA
    54
    My pool went from dark green to cloudy blue in just one night.
    Put 3 and a half jugs of bleach last night at sundown to make the FC 14 at a 20 cya. Was 4.5 FC just now. Added 2 more jugs to get back up to FC 12.
    Vinyl Liner
    Cartridge Filter
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    20,299
    Quote Originally Posted by Corrik View Post
    Outstanding! Remember it's not enough to just keep up the FC levels. You need to brush until your arms can't take any more (or lower back, whichever comes first) to separate the slimy protective biofilm from the algae so it will die and vacuum/scoop as much organic debris out as possible, even if it means working blind.
    May 2016
    Pittsburgh/PA
    54
    I am scared to brush right now because my 2 year old threw a toy car into the pool yesterday and I am afraid since I can't see it that I might scrape and rip the liner.
    Vinyl Liner
    Cartridge Filter
    Paul & Crystal's Avatar
    May 2014
    Oklahoma City, OK
    539
    Maybe use your leaf net to find it?
    60K 53 X 23 X 3'-10' IG Grecian Concrete aka "The Beast"
    TF100 XL with Speed Stir
    Dolphin M500 aka "The Beast Master"
    Sta Rite Max E Pro 2 HP - Hayward Pro Series Sand Filter S310T.
    My Pool Thread: Old School Pool
    May 2016
    Pittsburgh/PA
    54
    Hoping it is cleared up today to find it. See when I get home.
    Vinyl Liner
    Cartridge Filter
    May 2016
    Pittsburgh/PA
    54
    Still SLAMming. = /
    Vinyl Liner
    Cartridge Filter
