Thread: Doheny Saturn - buy now or wait?
    May 2016
    Troy IL
    484
    I want a robot. I'm tired of vacuuming manually mainly because of the way my pool is plumbed and the small skimmer that has no access from the top, only the mouth. I've taken care of pools all my life, and I've never hated vacuuming so much.
    Anyway, I'm looking at the Doheny Saturn by Dolphin for $649 - $10 if I order by May 1 (coupon code). Should I pull the trigger and be happy all summer? Or wait and hold out for a better deal on this or perhaps another model?
    My pool is a roughly 17'x30' sport pool with around 17,500 gallons of water. I think I can get away with short cords and less expensive robots because of the size of my pool, plus I really don't want to spend any more than $650.
    What would you do?
    17,500 gallon IG Vinyl
    Pentair Tagelus TA60D Sand filter
    Pentair Challenger 1.5HP pump CFII N1 1.5A
    Taylor K-2006-A, Stenner 45MPHP10 auto chlorine feed
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Re: Doheny Saturn - buy now or wait?
    Well, if you wait 5 weeks and save 50 bucks is it worth 10 bucks a week to clean your own pool or would you rather pay your Saturn 10 bucks a week to clean it?
    My vote is to locate a time machine and buy it last year, that way you'd already have had your answer.
    Geebot
    Chicago, IL
    30K gal, InGround Plaster Finish, 3.5'-9.5', Maytronics S300 Cleaner
    bmoreswim's Avatar
    Jul 2012
    Central MD
    4,152
    If you have some risk tolerance, here's the same robot (a Saturn twin) refurbished for $260 less. Only difference is one year warranty vs two. And you'll have to mail in for warranty service. https://www.poolpartz.com/dolphin-e10-refurbished. Or the Active 10 for $20 more of you like that name and color scheme better.
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    May 2016
    Troy IL
    484
    lol, thanks all, good points. $50 savings isn't enough to make me want to wait all summer, and it is likely all I'd see anyway. So if I want that robot, I think I shall just buy it.
    @bmoreswim That was tempting until I realized it was the E10 which is for above ground pools and only cleans floors. would it clean my walls in an in ground pool since the corners of my pool aren't 90 degree angles like in an above ground pool? I want something that'll vacuum and scrub my walls and floors.
