Thread: New pool owner checking in
    Apr 2017
    Las Vegas
    20
    I am finally all up and running with all of my installation of the new pool done.
    I think I am a little off, but close on my chemistry. Here is what I was at last night.
    FC: 4
    pH: 8
    TA: 140
    CH: 475
    CYA: 50ish
    Salt: 3250
    I have been to Leslie's where they give me bad advice like I need to shock it every week and also need Perfect Pool every week, but I don't listen to them.
    I put some muriatic acid in yesterday to bring the PH down but think I need to put more in. Do I need more stabilizer too? I did two gallons of pool conditioner a few days ago but not sure if I need more or another product.
    Also, I have a raised spa that overflows into the pool when the pool is running. The PB set up my schedule to just have the pool run, do I need to run the spa setting too? I have a sparkling clean pool but the spa always has dirt in it.
    22,000 Gallon In-ground Gunite / Plaster (New pool, plaster done March 2017) with Spa
    Pentair Intelliflo variable speed pump and 2HP water feature pump
    Pentair Easy Touch System w/ Iphone app
    Pentair Gas Heater and Pentair Auto Vacuum
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: New pool owner checking in
    Welcome aboard!
    You do need to get your pH back down. pH rise is directly tied to your TA level and the amount of aeration your pool has in general. High TA = faster pH rise. Lots of aeration such as waterfalls, deck jets, spill overs and even SWG units give faster pH rise as well. As you add acid, your TA level will come down. Continue to lower your pH to 7.2 and allow it to rise naturally until your TA is closer to 60-80 ppm. You will see slower pH rise at lower TA levels. Eventually, your pH should stabilize for longer periods and you should only lower it when it goes ABOVE 7.8. You should raise your CYA slightly. See the Pool School - Recommended Levels Add it incrementally so as not to overshoot your target.
    You should have daily circulation in the pool or spa to keep them both sanitized.
    Isolated Spa - 345 Gallons
    Mod Squad mknauss's Avatar
    May 2014
    Laughlin, NV
    10,941
    I would wait on the stabilizer for a few days to be sure what you have. You did not state which SWCG you have, hopefully at a minimum the IC40. You will be running it quite a bit in midsummer to maintain FC.
    Unless your Auto Vacuum cleans the spa too you will have dirt in it. Welcome to our dusty desert!
    Watch your CSI closely. You will get scale quickly unless you manage it. You will need to get the TA down to ~70 in the short term.
    Take care.
    6000 Gallon IG Fiberglass with integrated Spa;Pentair CCP240 Cartridge Filter with Pentair Intelliflo VS Pump and HTR250 heater. IC40 SWG. EasyTouch 4. Dolphin Active20 Robot "Roadrunner", TF 100 Test Kit w/SpeedStir!
    CLICK HERE to Become a TroubleFreePool.com Supporter!! Pool Math App
    Marty
    domct203's Avatar
    Jun 2015
    CT
    3,896
    I would consider raising that CYA as you have a SWG, and the Vegas sun. A CYA of 70ppm is the minimum recommended with a SWG.
    Chlorine CYA Chart
    Your pH is most likely high from your high TA level. As you add MA to lower your pH, the TA will drop as well. Eventually you should reach a point there pH & TA are happy together and pH rise slows considerably.
    I don't have any direct experience with a spa, but the aeration created by the spill over will also cause pH to rise.
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    May 2014
    Laughlin, NV
    10,941
    I need to balance the statements that pH rise will 'slow' once your TA is down. Not really. Our hard water here which is high in TA will require regular additions of MA. In my tiny (6000 gal) pool I add ~1 cup of acid every 5-7 days. Part of that is needing to keep the pH lower to manage CSI. The CH will climb quickly here due to our massive evaporation rates. You need to plan to drain your pool every 24 months or so as the CH will rise to unmanageable levels.
    Marty
    Apr 2017
    Las Vegas
    20
    Thanks for the advice. I will add some more MA today. Do you guys measure out precise amounts of MA of just eye ball it? I wasn't sure if I should be pouring this stuff in some sort of measuring cup as I assume you don't want to get it on your skin.
    So do you think I should have my spa turned on a schedule on my easy touch along with the pool? When I turn 'on" the spa the jets come on so I was just confused as to how filtered the spa water gets on pool on mode or on spa on mode.
