Results 1 to 9 of 9
Thread: New (to me) Pool Owner with Test Results
    Apr 2017
    Turlock, CA
    5
    Good Morning,
    I just purchased a home a few months ago that had a pool (built in 1990 if that matters). It's a 23k gallon gunite with a Hayward sand filter and Kreepy Krauly sweep. The deep end and tops of steps has some brownish stains - I believe these are organic because I placed a chlorine puck on one of the stains for a few minutes and it cleared up a in a circle. I found some pictures of the backyard from when the home was foreclosed on in 2012 and it looks like the pool was drained and left as a swamp in the deep end.
    Since purchasing I have been running the filter 3 hours a day, sweeping weekly, backwashing monthly, and keeping the chlorine tab floater replenished with about 3 pucks at any given time. This has kept the pool fairly clean for the winter since we are not using it. I had the water tested a couple times from a pool store and they said everything looked fine.
    Now that it has started to warm up in CA, I've noticed that it got a little cloudy, so I upped the filter time to 6 hrs/day. Then I found this great forum and figured I would check in here before going any further. Based on the advice here, I bought a Taylor K-2006 and just ran my first test:
    CC - Filled tube to 10ML and put to .5 dippers of 0870 - turned pink right away
    FC - 4.0 PPM
    PH - 7.0
    Alkalinity - 80
    CH - 320
    CYA - >100 it was about 1/2 an inch below the 100 mark!!
    Any advice on where to go from here? Also, will getting the chemicals all balanced right remove the organic stains on their own or will I need something different for that problem?
    Aaron
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    10,158
    Re: New (to me) Pool Owner with Test Results
    Welcome to the forum. You realize that every time you add a puck you're also adding CYA. Only way to lower you to a more reasonable 60 is to replace water. Then maintain your FC level in line with that per Pool School - Chlorine / CYA Chart. Ph needs to be 7.2 minimum. Pucks lower your PH as they are acidic as well.
    Apr 2017
    Turlock, CA
    5
    I didn't know about the pucks (or what CYA is for that matter) until coming to this forum a few days ago. I'll certainly be buying bleach now. Off to drain the pool now.
    23k gallon gunite with Hayward sand filter, Kreepy Krauly sweep, Century 1.5hp single speed pump.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    20,312
    Quote Originally Posted by ambrown307 View Post
    Do it while you can!
    I started with CYA over 200 and water restrictions that wouldn't let me drain. It was a real PITA that first year.
    Apr 2017
    Turlock, CA
    5
    Ok. So I just drained about 3/4 of the pool and have started refilling, which should take around 2 days. Should I be adding anything while it's filling, or just wait until it's full, test, and go from there?
    Richard320's Avatar
    Jan 2010
    20,312
    If you're paranoid, you could add some bleach. Pour it into the fill stream and then brush things around a little.
    I don't know that I'd bother. If the pool was otherwise healthy, it'll take more than two days to go green.
    Apr 2017
    Turlock, CA
    5
    Thanks Richard. Yes the pool was actually pretty healthy already - I just didn't want to start the summer with the CYA level as high as it was. Thanks again!
    Apr 2017
    Turlock, CA
    5
    Just to update - I was able to test after refilling and running the filter for about 20 minutes. Results look pretty good:
    FC: 1.0
    PH: 7.5
    AK: 140
    CH: 150
    CYA: 35
    I assume at this point I just add bleach and maintain?
    Apr 2010
    East Texas
    10,158
    Sounds like a winner. Monitor your daily Fc loss.
