Results 1 to 10 of 10
Thread: DIY vs. Pros
    PureLuck's Avatar
    May 2016
    Hopkinton, MA
    126
    DIY vs. Pros
    Ok, just wanted to share.
    This is the best forum!
    We bought our house 8/2015
    Paid the pool company "professionals" $325 to close the pool. (Plus the cost of chemicals that we bought)
    April 2016- paid to have them open the pool.
    Here is the breakdown:
    * Took off cover- laid it on lawn to dry ( we had to roll it up and put away)
    * dropped in ladder
    * Took out plugs(dropped 1 in murky water and left it)
    * Turned on pump
    * Put in chemicals (again that we paid for)
    $425 paid
    - they did not test water, never came back to put in filters, and left cover on freshly mowed lawn.
    --- also, murky green water they blamed on a mild winter
    Forward to fall 2016-
    Thanks to help from all you, we closed the pool ourselves in a few hours. Longest part was draining out some of the water.
    Cost: $8.00 for chlorine
    (Very mild winter, Warmer than last)
    We were scared to open up a green mess.
    Nope! Just some debris and dirty stuff.
    Started pump, didn't drop any pieces into the pool, and saved us tons of money.
    TFP rocks! And those "pros" should learn something from this forum.
    In ground Liner, MBP-125A Heat Pump by Aqua Heat , built 2003, 18x37 Grecian style, System 3 sta-rite filter. @22,000 gal, tftestkits TF-100 & 1766, USQ1102pump installed 6/2016, new liner installed 07/2017. Circupool SJ40 SWG (7/2018), Dolphin S300i 7/2016
    Jun 2014
    17,348
    Re: DIY vs. Pros
    That's awesome! Fantastic testimonial. Thanks for sharing.
    Nectarologist's Avatar
    Apr 2015
    New York
    471
    Re: DIY vs. Pros
    Awesome! Makes you want to show the pool company how it should be done but they won't listen so not worth your time. How did you clear the lines of water? Just let gravity take over once the water level was low enough I assume?
    Inground, vinyl liner, 16 x 32 (approx. 21k gallons), roman end w/ bench, 2 Jandy LED lights
    Pump: Jandy Flopro, 1.5 hp Heater: Raypak, 266k btu (P-R266-A-EN-C; nat gas) Filter: Jandy C340 (cartridge filter) Robot: Doheny's Dolphin Discovery SWCG: Circupool RJ45
    PureLuck's Avatar
    May 2016
    Hopkinton, MA
    126
    Re: DIY vs. Pros
    Quote Originally Posted by Nectarologist View Post
    Actually, we used a wet dry vac. It was pretty easy. I was worried that it wasn't going to work as it is 9 feet deep. But, we got bubbles out of every part.
    People here helped me with my worries, and it was all good.
    (Just wish my little icon with the supporter thing showed up on my taptalk - as we love tfp, and support it)
    May 2016
    West Bloomfield, MI
    758
    Re: DIY vs. Pros
    Quote Originally Posted by PureLuck View Post
    Maybe not! From where I'm sitting, the "pros" have found a way to charge a lot for doing very little. Great business model!
    12,000 gal Diamond Brite indoor​ pool. Pentair Triton TR-60 Sand Filter +added DE, Lochinvar Energyrite ERN-200 gas heater, Pentair Multi-valve, Pentair SuperFlo VS pump, TF-100 kit, Pool Math App - iOS
    PureLuck's Avatar
    May 2016
    Hopkinton, MA
    126
    Re: DIY vs. Pros
    I keep telling my teenage son that he could go around offering his services for half the price of the pros and make a killing!
    May 2016
    Huntsville AL
    39
    Re: DIY vs. Pros
    Until I got wise on this site I would take a bottle of water to the Jewelry Store, I mean Pool Store and could never get out of there without dropping $100 to $150 in chemicals.
    15,000 gal In-Ground Vinyl, Jacuzzi Laser Sand Filter w/ 1.5hp Pump , Polaris Cleaner w/ 1hp Pump, Taylor K-2006-C Test Kit
    blakeusa's Avatar
    Jul 2010
    Ashford, CT
    572
    Re: DIY vs. Pros
    The larger local pool company in my area does not remove any equipment from the elements (which I think is not good to leave a $8K of pumps, chlorinators, heaters etc) sitting outside all winter in CT / New England. That is just the start... I just think its worth a couple of hours to remove it and put it in a warm garage or at least an indoor area. They say it is not recommended to move the equipment...
    25k 20x40 Gunite w/ integrated Spa & Caribbean Blue Plaster, Curved Bluestone Coping, Deck Jets
    Pentair Easy Touch/Wireless, Sta-Rite Intellipro SRVS Pump, Intellibrite Lights, & Pentair IC40 Cell, Sta-Rite 450sf Cartridge filter
    Heated from Central Boiler - Outdoor Wood Furnace & Triangle Tube Max Heat Exchanger
    ColorQ Pro
    TF-100
    Feb 2015
    Leesburg, Va
    165
    Re: DIY vs. Pros
    Congrats on the do it yourself! We did the same this year.
    We ran into a self inflicted snag when we turned on the equipment, we had not opened the air flow in the filter so our pump kept shutting down.
    My wife and I went back inside after 40 minutes, I'm furiously writing up a TFP help me post and then she says... you know, maybe we need to open the valve at the top of the filter..... Dooh! We cleaned our filter several times in the past and know what to do, why should this be different.
    So the pumps all worked in the end.
    Thanks to TFP we saved $400
    Pool build spring/summer 2015. IG. 750 sq ft pool. 40 sq.ft spa. 18ft x 42ft rectangle, 31,000 gallons, SWG, DE Pentair model, 2 boosters variable speed model, heater master temp Pentair, Quartz finish Aegean Green, CoverStar Automated Pool Cover, Kreepy Krawley Platinum, TF100,SpeedStir My Build in Progress
    PureLuck's Avatar
    May 2016
    Hopkinton, MA
    126
    Re: DIY vs. Pros
    Quote Originally Posted by poolnorthernva View Post
    I spent my first season skiing just the opposite of that. I was vacuuming with all returns open. Would take me 4 hours to vac. 🤣 TFP saved me there as well!
