Results 1 to 7 of 7
Thread: Hayward .75 eyeball turning angle, leaking normal?
    Jun 2016
    Pittsburgh, pa
    369
    My hayward widemouth came with a hayward .75" eyeball which i installed on my intex pool.
    I currently have it aiming upward and as much to the left as i can.
    I think ideally i want this aiming down and to the left.. however.. i noticed when i first installed it, if i didnt crank it all the way to the right/clockwise to where it is now, it leaked around the thread around the "eye".. is that normal? IE: to turn downward i think ill have to loosen it.. it just doesnt rotate freely but must rotate around the inner threads?
    Anyone know on this?
    Thanks
    My Intex Ultra 18'52 build
    My SmartPool Solar Panel Build
    6981 Gallon + Hayward 1.5HP Matrix + 21"
    Solar S601P SmartPool 160sq feet solar panels
    Intex 7K Gallon SWG, Hayward WideMouth
    CJadamec's Avatar
    Apr 2016
    Quaker Hill, CT
    2,192
    Re: Hayward .75 eyeball turning angle, leaking normal?
    The ring on the inside of the pool holds the eye in place. The eye itself is just a ball with a hole in the center. If you loosen the ring holding the ball, then re-aim the ball where you want it, then tighten the ring back down.
    Chuck-
    15x30 AG, Pentair Superflo VS, 19" sand filter, TF-100 test kit
    Aqua Comfort ACT750 heat pump / 6x20 ground mount solar panel / DIY automation
    Photos of 2016 Build, Inside Your Breaker Panel, Free Copy of 2017 NEC code
    TFP is AD Free and is funded solely by member support click here to help
    domct203's Avatar
    Jun 2015
    CT
    3,913
    Quote Originally Posted by theskyisthelimit99 View Post
    Thanks
    How do you see an underwater leak? Your return eyeball should be underwater. If it's inside the pool where it 'leaks', it's trivial unless it's so bad that it effects the performance of the return jet.
    Or am I missing something here LOL?
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    Jun 2016
    Pittsburgh, pa
    369
    Quote Originally Posted by domct203 View Post
    lol, this was before my return was completely surrounded by water.. the one that came with this widemouth doesnt turn.. at least not the eye itself.. I think this is a picture of it The leak was on the part that twists with the vertical lines on it in the picture.. until i used a wrench and tightened that, it leaked around that inner threading
    Perhaps i should replace the one that came with the kit with this one?
    domct203's Avatar
    Jun 2015
    CT
    3,913
    Those are the same eyeballs.
    If you unscrew that outer ring, you can remove the eyeball. Clean both the eyeball, the 'socket' part in the return & back side of the outer ring. When you reassemble lightly coat the eyeball as well as the threads on the inside of the outer ring with silicone o-ring lube and reassemble hand tight.
    When I adjust mine, I loosen the outer ring a bit, re-position the eyeball, then hand snug the outer ring. the o-ring lube keeps everything moving (somewhat) freely.
    Don't over tighten it, if it's too loose you'll know by the eyeball moving under the water restriction pressure.
    Don't worry about leaks on the inside.
    Dom - TFP Guide
    Jun 2016
    Pittsburgh, pa
    369
    Ok, but the eyeball the 0.75" part.. doesnt move.. only the whole inner ring correct? at least thats how it is on mine.. if i remove it now, may leak on the other side, or maybe not, guess ill find out
    domct203's Avatar
    Jun 2015
    CT
    3,913
    The eyeball assembly is the outer ring, eyeball, and inner sleeve, with the latter threaded to screw into your 1-1/2" wall fitting.
    The outer ring unscrews from the threaded sleeve, loosening its grip on the round eyeball so you can adjust it.
    I leave the ring and sleeve just tight enough to hold the eyeball in place. When I need to remove/install the threaded sleeve to the wall fitting, I use this:
    https://www.amazon.com/Hayward-SP141...d+eyeball+tool
    I found this exploded view:
    That assembly screws into the wall fitting.
    Dom - TFP Guide
