Thread: Once a bromine pool, always bromine ?
    CactusPool's Avatar
    Jan 2017
    Bullhead City, AZ
    10
    My new outdoor pool went into service on March 16th with bromine as the sanitizer. I've been getting advice from others to switch to chlorine. I like the bromine water and I am reluctant to switch. To do so means draining the pool or use sodium thiosulfate to neutralize the bromine. If not done, any chlorine introduced will only reactivate the bromine "in the bank". However, since bromine is not UV stabilized will it not deteriorate in short time if I don't add any more? If the bromine is so "ever lasting", why do I have to keep adding more? The "once a bromine pool, always a bromine pool" seems to be flawed. Otherwise, using chlorine to reactivate the bromine over and over may prove to make bromine less costly than it appears. Any comments on this will be appreciated.
    "L" shape, 42' x 14' x 20', 19,000 gallons; 28 mil vinyl, with 6" sun skirt, over concrete shell. One 2" skimmer/suction line, two 1.5" suction/vacuum lines, and three 1.5" returns. Hayward SP2307X1 Max-Flo XL Pump-1HP single speed, Hayward DE720 Pro-Grid Vertical DE Filter, Hayward SP0715R50 Vari-Flo Multiport Control Valve and Pentair 320 Chlorine Tab Feeder (which I no longer use).
    CJadamec's Avatar
    Apr 2016
    Quaker Hill, CT
    2,192
    Re: Once a bromine pool, always bromine ?
    There is a good description on how to use bromine HERE. Mostly you find bromine in spas as it has advantages there that sometimes justify the cost.
    Chuck-
    15x30 AG, Pentair Superflo VS, 19" sand filter, TF-100 test kit
    Aqua Comfort ACT750 heat pump / 6x20 ground mount solar panel / DIY automation
    Photos of 2016 Build, Inside Your Breaker Panel, Free Copy of 2017 NEC code
    TFP is AD Free and is funded solely by member support click here to help
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Once bromine, always bromine is certainly true. When bromine is depleted by sunlight or organics, it reverts to bromide ions. These bromide ions remain in the pool. As soon as a strong oxidizer is added (bleach, MPS, etc.) bromide is preferentially converted to bromine, immediately consuming the oxidizer added. You can maintain a bromine pool or spa once you have a bromide bank with any oxidizer you choose and it will still be a bromine pool. Bromine tablets are used because they are convenient. These tablets do also contain DMH which partially stabilizes bromine but doesn't do it very well. It also prevents bromine/bromide from eventually dissipating from the pool. If you were to only treat your pool with bleach for an extended period of time, eventually the bromide would outgas and you could treat as a chlorine pool. How long that would take would depend on how much DMH and bromide bank is in the pool.
    For indoor pools and spas, bromine is a valid alternative to chlorine. For outdoor pools, bromine is an inferior option purely from a long term cost perspective.
    Isolated Spa - 345 Gallons
    CactusPool's Avatar
    Jan 2017
    Bullhead City, AZ
    10
    By adding potassium monopersulfate to oxidize on a regular basis, the bromine is reactivated. Thus, the need to add more bromine is minimal. Using bromine is a less costly sanitizer than chlorine once the "bromine bank" is established, especially in a pool where the temperature will exceed 85 degrees Fahrenheit.
    Feb 2014
    Central Minnesota
    5,080
    Quote Originally Posted by CactusPool View Post
    This is simply not true for an outdoor pool. Bromine's CYA analog, dimethylhydantoin (DMH), only marginally protects bromine from UV light. Much less than CYA protects chlorine from UV light. Daily bromine losses to UV will be higher than chlorine in any outdoor pool.
    Bromine VS Clorine
    MPS is likely the most expensive way to convert bromide bank to active bromine. Bleach is much cheaper.
    Do you have any data that supports pool water temperature induced differences in bromine and chlorine decay?
