Thread: What is causing my belly clamp to corrode?
    Apr 2016
    Houston
    22
    The powder coating on my belly clamp is peeling away. Time to buy a new one? What could be causing it to corrode like this? Is this normal wear & tear or something else?
    16,200 Gallon
    In-Ground Pool, Plaster
    Cartridge Filter
    40,893
    Re: What is causing my belly clamp to corrode?
    That is certainly weird ... you don't happen to store muriatic acid near the filter do you?
    Apr 2016
    Houston
    22
    I don't store any chemicals near the pump filter. I've lived in the house for 1.5 years. Can't speak for what the previous homeowner did.
    16,200 Gallon
    Cartridge Filter
    This one time, at band clamp...
    In April 2009, Hayward introduced the cast aluminum band clamp part number DEX2421JKIT.
    Most of the time, aluminum is fairly corrosion resistant. However, sometimes it begins to corrode and when it does it can really get bad.
    I would suggest sanding and painting it to reduce further corrosion.
    Support the site
    CJadamec's Avatar
    Apr 2016
    Quaker Hill, CT
    2,192
    If you plan on painting it you will need to use an aluminum etching primer for your top coat to stick. Aluminum is notorious for being hard to get paint to stick.
    Cheap cast parts like that can be prone to that type of corrosion due to impurities in the casting.
    Chuck-
    15x30 AG, Pentair Superflo VS, 19" sand filter, TF-100 test kit
    Aqua Comfort ACT750 heat pump / 6x20 ground mount solar panel / DIY automation
    Photos of 2016 Build, Inside Your Breaker Panel, Free Copy of 2017 NEC code
    TFP is AD Free and is funded solely by member support click here to help
    Sep 2013
    Nashville, TN
    405
    Mine looks the same, I attribute it to when I blead off the air and get some salt water sprayed on it
    18x36 Vinyl, sports depth, 8' Roman steps at each end. Hayward 1.5hp 2speed pump, catridge filter, 2 skimmers, no main drain, 3 SR Smith Treo LED lights
