Results 1 to 7 of 7
Thread: couple of questions on installing a new sand filter (positioning and fittings)
    Apr 2017
    Upstate NY
    145
    Question couple of questions on installing a new sand filter (positioning and fittings)
    Hi all,
    While I'm waiting for my TF-100 kit, I'm definitely keeping busy... I'm installing a new Hayward S244S filter, using my existing Pentair SuperFlo pump. The lines coming out of the ground only leave a little bit of room for the pump and filter on my concrete block... so basically it has to be like this:
    1) How strict is that "minimum clearance" part of the owner's manual? I could probably dig out a part of the lines where they meet the ground and get it all to come out another 1" or so away from the wall, if it helps any. It would be a big pain though - I'd have to probably replace the 3" pavers with 4" pavers, and buy an additional 1" concrete slab to sit under the filter.
    2) Do I need to install a union ball valve on the waste port of this filter? It's a Vari-Flo Valve. For example, when I turn the valve to FILTER or CLOSED or whatever, will water not come out of the waste port? And will it only come out of the WASTE port when I turn the valve to WASTE, BACKWASH, or RINSE, etc.? I'm just wondering if I need to cap it for when it's not in use or attach a union ball valve to it. Or will this nylon 1 1/2" to nipple adapter suffice? (I have a roll-out 25ft waste hose thing)
    Thanks!
    SLAM Chlorine/CYA Chart PoolMath Pool Chemicals
    20,000gal IG Vinyl Pool, Village water
    Hayward S244S Pro 24-Inch Side-Mount 1.5" Sand Filter w/ Sidley Sand
    Pentair SuperFlo SF-N1-1A/340038 1.0 HP Pump
    TF-100 Test Kit w/ SpeedStir
    domct203's Avatar
    Jun 2015
    CT
    3,890
    Re: couple of questions on installing a new sand filter (positioning and fittings)
    I would be worried about the filter moving/vibrating during use and rubbing against that wall, weakening the filter housing in that area. Can't you swing the filter (in an arc centered on the pump connection) away from that wall?
    What about using flexible hose at the pad?
    Put a 90deg fitting on that waste port, and no, you don't need another valve, nothing should come out of that port unless the MPV is on backwash.
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    Apr 2017
    Upstate NY
    145
    Quote Originally Posted by domct203 View Post
    Ah yeah, the rubbing from vibration would probably not be good. Thanks for the ideas! Rotating the filter away from the wall would do the trick but I'll have to install a 45 elbow on the return. That's doable though.
    I don't understand what you mean with the flexible hose. For going from the pump into the filter?
    And thanks for the info on the waste port. The old filter this house had didn't have a Vari-Flo valve.
    domct203's Avatar
    Jun 2015
    CT
    3,890
    I was thinking if you used flexible hose from the stubs in the ground to the pad it would give you more freedom on the pad.
    Can you post another pic showing all the plumbing at the pad including the lines coming out of the ground?
    Dom - TFP Guide
    Apr 2017
    Upstate NY
    145
    Sure!
    BTW I rotated the filter, so it's at a bit of an angle compared to the pump.
    Thanks again!
    domct203's Avatar
    Jun 2015
    CT
    3,890
    Wow, that sure is a tight spot!
    Glad it's working out so far.
    Dom - TFP Guide
    Apr 2017
    Upstate NY
    145
    Indeed! Yeah I think it will work out w/ the 45 elbow, so thanks! Here's my plan w/ the return line.
