Thread: How do we add liquid cya?
    Apr 2017
    Jonesboro ga
    13
    Do you add to skimmer or can you drizzle into pool?
    Thanks!
    Bill and Robin
    33000 IG vinyl liner. Hayward salt generator.
    Jan 2012
    'burbs of Augusta, Georgia
    8,557
    Re: How do we add liquid cya?
    Adding to the pool in front of a return is fine. Its a thick liquid so I'd make a point of brushing a bit and leaving the pump running a while to mix it in good.
    Yip
    Skippy's Pool Cooler --> Skippy's New Fountain Our Build --> Our Pool Solved Our Sloping Yard
    Uncle Salty's Avatar
    Feb 2017
    South Carolina
    221
    With pump running I just walked it around the pool and then brushed after, make sure to shake the heck out of it before and during. Also dunk the jug in the water and shake to get it all out as it tends to come out clumpy. Works like a charm though, hit my number bang on thanks to Pool Math.
    Salty
    20X40 30,000 gal. Vinyl, AquaPlus Automation w/ T-15 SWG & AquaConnect, EcoStar SP3400VSP pump, ProSeries S310T2 Filter, H Series 400FDN Heater, Sense/Dispense with Stenner Pump, ColorLogic X 3, TigerShark RC990, ​Borates, TF-100 test kit, K-1766 & Speed Stir Finally done! Well Almost
