Thread: Maybe a stupid question on coping
    Aug 2016
    Toronto, Ontario, Canada
    23
    Hi everyone,
    We have been looking at pavers and finally settled on one. We want a uniform look so we wanted the coping to be an exact match to the paver stones. The problem is that the stone that we would use for coping is not really made as pool coping but rather as a piece that would sit on top of a wall, and the issue is that the edges are somewhat sharp. Does anyone know if it is possible to somehow smooth the edge slightly, maybe by sanding it down or something else.
    Sep 2016
    Dallas, Texas
    188
    Re: Maybe a stupid question on coping
    Quote Originally Posted by ekadd View Post
    Hi everyone,
    We used Lueters Limestone. We had a choice of bull nose (rounded) or rough cut. Both are just different finishing methods so I would say if the installers are from a rock supplier, they could easily do it
    Matt- IG gunite pool and spa built Summer 2016: 32' x 20' overall with two 4' x 8' tanning ledges. 6'x6' attached spa with spillover. Depth 3' to 5' to 4'. 16.4K gal. Lueders Limestone retaining wall and coping. Equip: Pentair SVRS vari. speed pump. Pentair 60 sq. ft. DE filter. Pentair Kreepy Crawly Plat. cleaner. Pentair MasterTemp 400,000 BTU NG heater. 1.5 HP spa air blower. Nature2 Sanitizer. Taylor K-206C. My 2016 Build
    Mar 2014
    Tampa
    107
    Quote Originally Posted by mwalling View Post
    Sent from my iPad using Tapatalk
    Have you considered travertine coping and deck perfect match
    blakeusa's Avatar
    Jul 2010
    Ashford, CT
    572
    You can grind or form a soft edge on pavers with an Angle grinder and diamond wheel. Its dusty/ dirty and you need to wear a mask.
    There are also pavers made just for pool coping.
    25k 20x40 Gunite w/ integrated Spa & Caribbean Blue Plaster, Curved Bluestone Coping, Deck Jets
    Pentair Easy Touch/Wireless, Sta-Rite Intellipro SRVS Pump, Intellibrite Lights, & Pentair IC40 Cell, Sta-Rite 450sf Cartridge filter
    Heated from Central Boiler - Outdoor Wood Furnace & Triangle Tube Max Heat Exchanger
    ColorQ Pro
    TF-100
