Results 1 to 16 of 16
Thread: Adding DE with Algae in Pool
    May 2016
    OKC, OK
    19
    Hi-
    Sorry if this has been asked before, my pool is a bit of a hot mess right now because I did not do a great job over winter taking care of it. I am about to start the slamming process, but had a question about how to time what I am doing.
    I am going to be taking apart and deep cleaning my DE filter. Normally when I am recharging my DE after a backwash I pour it through the skimmer, since the pool currently has algae should I re-add the DE through the skimmer after I deep clean the filter with the algae water or is there a better process for me to be following?
    Sorry if the question is unclear, I can try to clarify if you all have any further questions...
    40,867
    Re: Adding DE with Algae in Pool
    Welcome to TFP!!!
    You have to add the DE through the skimmer.
    Honestly, if it was me, I would consider doing the SLAM first (backwash and recharge as required ... when the pressure rises 20-25% over the clean pressure) and then after you complete it, then tear down the filter and start fresh.
    May 2016
    OKC, OK
    19
    Good idea.
    I was thinking about maybe doing that, but wasnt sure what the best practice was. Thanks for the advice!
    one other question along these lines - my area is forecast to get 3 inches of rain through Saturday. I'm wanting to get this process started ASAP, but do you think I should hold until after this rain passes?
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,316
    As long as you don't mind going out in the rain every few hours, you are okay to start anytime
    Bob - INTEX 12x24 owner (not setup yet), 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    40,867
    Rain does not really impact the SLAM process ... other than you getting a little wet.
    You could drain your pool 3" (assuming you can still run your pump) and let the rain fill it back up if your CYA is on the high side.
    May 2016
    OKC, OK
    19
    Thank you both, appreciate your help.
    20 X 40 33k gallon igp, with vinyl liner. Pentair DE Filter. Jandy 2HP Pool Pump. Currently shopping for automatic pool cleaner...
    May 2016
    OKC, OK
    19
    I'm about to take apart the filter and clean it, should I backwash first or does it not matter?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    20,301
    Quote Originally Posted by dvp View Post
    Your choice. Either way, wear old clothes.
    May 2016
    OKC, OK
    19
    Can't lie, I'm a bit nervous about this whole "deep clean the filter" process lol
    Richard320's Avatar
    Jan 2010
    20,301
    That's normal. But after you've done it, you'll wonder how in the heck a pro can get away with charging so much to do it.
    40,867
    May 2016
    OKC, OK
    19
    Thanks again, appreciate you all's support
    30,946
    dvp,
    Having two threads about the same subject is incredibly confusing to folks trying to help you. They are too long now to consolidate but please keep all future posts under this thread or the other.
    May 2016
    OKC, OK
    19
    Sorry! They originally started out as different questions I swear
    ckk81's Avatar
    Jan 2015
    Kalamazoo MI
    235
    Welcome to TFP!!!
    If you haven't pulled it apart yet I would agree to wait. Backwash and recharge while you're in the thick of the fight.
    30K? gal (20x40, 3ft shallow to 8-9ft hopper), Vinyl IG, single speed 1HP pump, Hayward Micro Clear DE-3600 filter, Hayward Aqua Rite SWG T15 Cell, Rheem/Raypack M206A heater
    kevreh's Avatar
    Jun 2007
    Annandale, VA
    412
    I "deep" clean my DE filter a couple times a season. Its pretty simple. Backwash first to remove most stuff, remove cover, open drain valve, and spray grid with garden hose. You just need to stand there and spray into the nooks and crannys. At the end of the season I might take the filter assembly out and clean it. Some pro's even take the assembly apart, but thats a major PIA and not worth the time imho.
    This year, when opened, I put the filter on recirculate and shocked my pool. Too much backwashing if I start the DE filter on opening day.
    Last, what really pays dividends in the spring is to a) shock the pool a few days before closing and b) use those floating things that hold pucks (put in pool right before cover is put on). Also, if its been a week or so of temps in the 70s or 80s, time to open! (so more algae doesn't grow)
    16x32 Concrete IG 24k Gallons
    Equipment: Carvin 525sf Cartridge Filter, Jandy Gas Heater, Vortex Solar Panels w/solar valve, 1hp Hayward Pump with 3/4 HP AO Smith 2 Speed Replacement Motor, Aquarite Saltwater Cell, Polaris 280 Dolphin Active 20 Robot
    Automation: Hayward Prologic Controller
