Results 1 to 13 of 13
Thread: What are the purpose of these Ortega valves?
    Oct 2016
    Chino Hills, Ca
    19
    http://i60.photobucket.com/albums/h2...ps5dbq1kqt.jpg
    When I turn the bottom one bubbles flow from the jets in the spa. The other just sounds like its draining somewhere????
    19,000 gallon in ground plaster pool with overflowing spa, Crystal Water Aqua Clean DE Filter (48sq/ft), Pentair WhisperFlow Pump, 8 gallon liquidator w/ 3/8" upgrade, Zodiac G3 Barracuda, TF-100 test kit
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Re: What are the purpose of these Ortega valves?
    Ortega valves are a version of a check valve. The purpose is to stop water flowing from the spa back to the pool when the pump shuts off.
    Oct 2016
    Chino Hills, Ca
    19
    Quote Originally Posted by pooldv View Post
    thanks.
    When and or under what what circumstances would I need to turn the handle/s in my picture I posted a link to?
    DFW, TX
    24,974
    If you click share, get links, copy the IMG code and paste it in your thread the pic will show up in your thread and people won't have to click out of TFP to view the pic.
    Like this
    Those are not Ortega check valves, they look like shut off valves to shut off flow either to or from the pool/spa.
    Oct 2016
    Chino Hills, Ca
    19
    Like this
    Thank you. When and or under what what circumstances would I need to turn shut off flow to the pool or spa?
    DFW, TX
    24,974
    Most likely only if you ever needed to change the pump or heater or something if there aren't valves up by the equipment pad. Are those under the pool deck near the pool? Maybe somebody repaired a leaky pipe or something in the past.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    20,296
    It looks to me like it says Pool under the handle. In which case, those are three-way valves.
    Edit: could be this: Valve,3 Port Positive, Ortega - G62131 - INYOPools.com
    DFW, TX
    24,974
    Yeah, to clarify when I said they aren't ortega valves I meant they aren't ortega valves with built in check valves. They are ortega diverter valves.
    Good catch Richard!
    Apr 2015
    tucson, arizona
    1,311
    When you want to use the spa turn both handles to spa, otherwise leave in that position to circulate pool. They are just an older version of the three way valve, water comes up from the center under the valves and then is diverted one way or the other depending on direction of handle
    Oct 2016
    Chino Hills, Ca
    19
    got it and thanks!
    Yes,they are under the cement deck and there are no other valves above ground by my equipment. I'm thinking I should install some?
    yes sir, written in sharpie under both handles.
    Oct 2016
    Chino Hills, Ca
    19
    Quote Originally Posted by kadavis View Post
    so is this correct?
    when I turn the lower valve to "spa" it activates the jets. When I turn the upper valve to "spa" it causes warm water from the heater to flow into spa? I can't test my upper valve theory because my heater hasn't work since I bought this house in 2008...
    Apr 2015
    tucson, arizona
    1,311
    One valve controls the suction to the pump from either the pool or spa and the other controls the return from the filter and heater to the pool or spa
    Oct 2016
    Chino Hills, Ca
    19
    Copy. Thank you
