Results 1 to 9 of 9
Thread: AB: Water line tiles - is it required?
    Mar 2017
    Atlanta/GA
    28
    I am in the process of getting some quotes for our 20x40 gunnite pool with AB.
    Is it necessary to have the old water tiles replaced or can we just put AB on that area (all the way till the coping) after demoing out old tiles? Does anyone have any pictures of pools done such a way? I am thinking why bother with plaster again if I am going with AB for long term maintenance.
    The quote indicated 2 line items; one for masking with fame resistant tape and epoxy coating; another for thermo polymer coating. Is that the norm?
    Thanks.
    25k IG Gunnite SWG; Hayward AQR15; Pentair FNS Plus Fiberglass Diatomaceous Earth Filter; Intermatic T10404R Control Center;Polaris 280;
    Centurion Booster Pump;
    Pentair SuperFlo
    JoyfulNoise's Avatar
    May 2015
    14,083
    Re: AB: Water line tiles - is it required?
    In my opinion, you want waterline tiles. The water line will always be the source of a "bathtub ring" of scale build up even in the most perfectly balanced water because the near surface chemistry of the water differs from the bulk. So it's easier to clean tile. When PebbleTek became a popular surface option, many people built pools with no waterline tiles thinking that the pebble finish up to the coping looked great. Fast forward a few years and they all developed calcium scale lines from evaporation and the PebbleTek is much, much harder to clean than tile.
    I would say the best option for your pool surface is to be submerged.
    Matt
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Does AB stand for Aquabright? Then I would not do a waterline tiles with Aquabright, it does fine out of the water.
    bdavis466's Avatar
    Aug 2014
    San Clemente, CA
    3,877
    If you remove the tile you'll need to replace it with something like plaster, Rapid Set or hydraulic cement.
    I've only done water features without waterline tile and they are holding up just fine.
    -Brian-
    Pool/Spa, Pentair Equipment
    bdavis466's Avatar
    Aug 2014
    San Clemente, CA
    3,877
    Even if you had no tile the coping would still need to be taped and masked off. I'm surprised that part of the process is a line item because it's necessary for the application.
    Either way, tile or no tile, making must be done.
    -Brian-
    Mar 2017
    Atlanta/GA
    28
    Thanks for confirming this. That pool color looks great. What is it?
    Dec 2016
    Douglassville, PA
    49
    Carlton is building our pool currently. They indicated over the winter when we were making decisions that AB does not require waterline tile but you certainly can have it. Logic behind the answer was that you don't need to keep AB wet like plaster. As to a scum line or whatever you might call it, we didn't discuss that. My wife and I decided we are going with AB with a waterline tile. Hoping to have our shell poured next week and photos of the AB and tile will follow.
    Pool Completed Spring 2017: 650 sq ft (26,000 gallon) IG free form (depth 3'-8'). AquaBright Finish (Blue Lagoon). Jandy DE Filter (DEV60). Jandy VS Pump. AquaCal SQ120R Heat Pump (110,000 BTU). AquaCal Autopilot SWCG. 1600 sq ft concrete.
    bdavis466's Avatar
    Aug 2014
    San Clemente, CA
    3,877
    Quote Originally Posted by aubie96 View Post
    Midnight Blue
    Here is a small feature that was done and you can see the coping still needed to be masked off:
    -Brian-
    Mar 2017
    Atlanta/GA
    28
    @bdavis466 - Nice to see the visual. Helps me a lot.
    @psualum - Looking forward to your build photos. Looks like the AB phenomenon is catching fire slowly but surely.
    @pooldv -- yeah, looks like thats the route I'd go if I go with AB. Looking at all options since we moved to this house recently and got a few more projects that need to be done. Mo' money, mo' problems.
    Pentair SuperFlo
