Results 1 to 10 of 10
Thread: Turning SWG off??
    Mar 2017
    Virginia Beach
    4
    Turning SWG off??
    So I am new to the SWG. Grew up with a chlorine tabs. Just had new system installed. Reading through the manual for the Salt System I came across this warning: This Salt System power supply must be connected to the same source power supply as the circulating pump provides water flow to the cell. Any isolation switch, time clock, or control that operated the circulating pump must simultaneously operate the Salt System control. Page 2 http://cdn.lesliespool.com/wpdf/INST...t%20System.pdf
    Does this mean that the pump timer should also run the SWG or that I need to manually turn off the salt system? Emailed Leslie's (who did the install and now owns Jacuzzi) and did not get much help.
    In Ground 20,000 Vinyl
    Jacuzzi VSP-150, Jacuzzi J-SS40 Salt chlorine generator , Jacuzzi Sand Filter
    40,848
    Re: Turning SWG off??
    Welcome to TFP!!!
    The pump timer should also cut power to the SWG. The flow switch should not be relied upon as the primary shut-off.
    Mar 2017
    Virginia Beach
    4
    Thanks for the response. Since my pump timer is not connected should I just be manually turning it off every night? I have just been leaving it on. Anyone else run into this problem?
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,837
    You should have it wired as soon as possible to prevent accidental operation with the pump off. In the interim, yes, please manually turn off the generator anytime the pump is off, not just at night.
    The risk, although rare, is an explosion. The flow sensor is designed to prevent that, but it could fail, so please don't take that chance.
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
    Jun 2016
    Martinez, CA
    241
    Have them come out and wire it properly since you paid for the work! When pump is energized (through the timer or pool controller) the same should happen for the swg. When the power is cut to the pump, it should cut power to the swg as well. Normally they just piggy back the wires from the pump power source to grab power for the swg.
    18,000 gunite pool/spa combo. Pebble tec, iaqualink rs8, cl580 filter, aquapure 1400, 400k btu lx heater, 10 solar panels, jandy 1hp, 1 1/2hp, and 2hp stealth pumps for circ, spa, waterfall
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Here is some inspiration to turn the cell off and get it wired to a timer pronto.
    New Member Swade
    Exploding pool!!!!!!
    SWG cell explosion
    GaryT58's Avatar
    Jul 2016
    Monroe, GA
    571
    You can run the pump without the SWG running, but you should not power on the SWG without the pump running. Many will power them from the same timer so the SWG and pump would run at the same time. If you want to be able to run the pump at times without the SWG, then you can use other methods - like two timers, automation, or a fancier timer that an control both.
    38'x16' Fiberglass pool - 3.5' - 8' deep - 19,000 gallons. AutoPilot Total Control SWG (RC-52 cell), Pentair SuperFlo VS, Pentair SD70 Sand Filter, Coverstar Automatic Cover, 10' board, PAL Treo lighting, Polaris 9550 Sport robot, Lamotte ColorQ Pro 7 test kit.
    Jun 2014
    Roseville, CA
    359
    While you are at it, you might want to consider a second controller for your SWG. In my case my solar panels had the pump running a lot of hours, which increased hours on the SWG, and had the tendency to over chlorinate my pool one week, and under chlorinate it the next. I wired a second timer in the series so the SWG:
    A - was energized only when the pump was running
    B - turned off and on per my timer only when the pump was running.
    So now I have independent control of the hours my SWG runs.
    SWG: CircuPool (5/2018) Universal 40; 3000ppm seems ideal;
    My Ideal Specs:
    FC 5; PH 7.4-7.6; TA 90; CH 350; CYA 75; = SI ~ 0.19
    14,000 gal, in ground, plaster, Cartridge filter, Borates
    TAYLOR K - 2006 Last Circupool SI30+ 4 years RIP.
    Mar 2017
    Virginia Beach
    4
    What timer did you buy for your SWG?
    Quote Originally Posted by Chuckiechan View Post
    Jun 2014
    Roseville, CA
    359
    Quote Originally Posted by mclemn View Post
    It's the T104 because I'm a 240VAC system. It was a stand alone box. Basically, you wire the two clocks together, and pull your voltage the pump circuit. Be sure to use non metallic conduit, and bond the box.
    To wire:
    How to wire Intermatic T104 and T103 and T101 timers
    Go down to "Two T104 timers for filter and cleaner"
    You are not supposed to use two wires to one terminal, but I did. Maybe and electrician can share a "code" hookup scenario.
    My Ideal Specs:
