Thread: Swim Pure Plus low voltage
    Apr 2017
    Oklahoma City
    5
    Hello. I have a Swim Pure Plus, T-15. At turn on, after the no flow light goes out, all looks normal. I go through the diagnostics and again all good. After about 15 seconds it stops generating and the Power light goes off. After several tries I noticed the voltage drops from 33.5 to 0, but starts climbing and usually stops at 19-20. Amps are 0. Could this be the thermistor? I do not think it is a bad cell (only 1 year old).
    Hayward tech support was no help. Said call out a service tech. Seems to be the answer every time they are called. Any help would be appreciated.
    Apr 2013
    Sacramento, CA
    2,769
    Re: Swim Pure Plus low voltage
    You need a bump
    Probably the thermistor. SL32-2R025 will work.
    How old is the box?
    Support the site
    Apr 2017
    Oklahoma City
    5
    Quote Originally Posted by gwegan View Post
    You need a bump
    What is a bump? The box is 6 years old.
    Bump just means bringing the post back to active.
    It's probably the thermistor.
    Support the site
