Results 1 to 8 of 8
Thread: Plaster stains
    lafonte98's Avatar
    May 2016
    Collinsville, IL
    60
    Plaster stains
    I have some stains in the deep end of my plaster bottoms pool. I have taped sandpaper to a brush I use to normally brush the pool which has helped remove stains in the past. Its just kind of a hassle. Does anyone recommend a brush made for this or had something they have tried that worked good?
    Greg
    30,000 Gallon Salt water, size (20ft x 26ft x 36ft), depth 3 1/2ft to 8 1/2ft. Plaster bottom with fiberglass kit walls installed in 2012. Pentair Filter (FNSP48) uses D.E. Motor is Pentair WFE-24 / 011517, HP 1.0 Easy Touch control system
    JoyfulNoise's Avatar
    May 2015
    14,077
    Re: Plaster stains
    Before attacking stains, it's best to figure out if they are metal stains, organic stains or calcium scale with embedded dirt. Each type of stain has a different approach to it for removal. Mechanical scrubbing only works if it's from a source that will not return; some types of stains recur in the same places because of more fundamental issues.
    Have you tried identifying the stains?
    Matt
    lafonte98's Avatar
    May 2016
    Collinsville, IL
    60
    Re: Plaster stains
    They are a light brown/yellowish color and typically show up in the same places. In the deep end where the floor curves up the wall.
    May 2015
    14,077
    Re: Plaster stains
    I would suggest using some Vitamin C in a sock to determine of they are metal stains. If they don't react (lighten) to that, then you can put a trichlor puck on it for a few minutes to see if it's organic/biological.
    Matt
    lafonte98's Avatar
    May 2016
    Collinsville, IL
    60
    Re: Plaster stains
    I assume I can do all of this under water without draining the pool?
    May 2015
    14,077
    Re: Plaster stains
    Yes. No draining.
    Matt
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Re: Plaster stains
    More info here, Pool School - Pool Stains
    blakeusa's Avatar
    Jul 2010
    Ashford, CT
    569
    Re: Plaster stains
    They make a little attachment (like a sponge with a reservoir) that you can put on a pole and put Muratic Acid or Vit C in a cap and then put the spot.
    I got one and used it on a few spots. Worked ok.
    https://www.amazon.com/Purity-Pool-O.../dp/B004VLB3VE
    25k 20x40 Gunite w/ integrated Spa & Caribbean Blue Plaster, Curved Bluestone Coping, Deck Jets
    Pentair Easy Touch/Wireless, Sta-Rite Intellipro SRVS Pump, Intellibrite Lights, & Pentair IC40 Cell, Sta-Rite 450sf Cartridge filter
    Heated from Central Boiler - Outdoor Wood Furnace & Triangle Tube Max Heat Exchanger
    ColorQ Pro
    TF-100
