Thread: pentair dual speed pump wired OK?
    There's no wiring diagram in the manual and only a small schematic on the motor itself. I don't want to burn up my motor so I've attached a couple of pictures in hopes of getting some feed back on the wiring. It's a 230v motor and I'm running the old electrical feed for a few weeks until I hook up an easytouch 8. Two hot legs and no neutral plus ground. The yellow and white wires are factory wires.
    Thanks
    19,600 to 22,500 gallon plaster pool. (Every calculator is different)
    1 1/2 hp pump Don't know the flow rate
    48 sq. ft. DE filter
    Polaris 280
    Real POS Laars LX Low NOX 400k heater (5 years old and it's DEAD)
    Re: pentair dual speed pump wired OK?
    Looks like there is supposed to be a neutral? Where does the white wire go? Is this a 2 speed pump?
    Quote Originally Posted by Brad S
    There's no neutral, don't need one. The white wire is a factory wire, I haven't and shouldn't need to touch it. Yes its a two speed pump.
    Polaris 280
    Guest
    Quote Originally Posted by platymapus
    To be clear, you do have three wires, right. 2 hot and a ground? That is the bare minimum for safe operation. I notice the "common" wire in the diagram, that is also referred to as "neutral" interchangably and is most likely linked with the ground.
    Got it figured out. The red wire to the 1st lead and for high speed the black goes to #2, for low speed black to #3. Once I have the easytouch set up Ill be able to take advantage of the dual speed pump.
    This whisperflo pump is a drastic improvement (noise) over my old a.o. smith pump.
    Time to relax and have a beer!
    Polaris 280
    Guest
    Great news!
    Yes, beer after the wiring is done. Not before.
