Thread: New pool sanity check - is my chlorine consumption high?
    Dec 2016
    Ft Lauderdale, FL
    2
    So, I'm about 10 days into a new pool and here are my test results from my TF-100 kit:
    FC 9.0
    CC 0
    pH 7.8
    TA 100
    CH 300
    CYA 60
    Salt system not running yet so I'm adding chlorine manually each day (8.25% bleach). Water is nice and clear
    I've read through all the great info here and feel like I have a handle on things but wanted to post just to get a sanity check as I feel like I'm adding a lot of bleach each day - at least a gallon.
    I was at 30 CYA last week and in the morning I'd have 4 or 5 ppm chlorine in the pool, then by night it would be ZERO chlorine. So I bumped my CYA up to 60 (as I read it should be higher once I start the SWG anyway) and bumped up the chlorine per the CYA/Chlorine chart and did an overnight drop test (OCLT) the last 2 nights. First night no drop in the Chlorine after 7 hours and last night it did drop 1 ppm after 9 hours.
    Should I just stay the course or is this chlorine consumption cause for concern?
    18k, IG plaster pool, Pentair 3hp Intelliflo pump, Pentair IC40 SWG (not currently on, new pool filled on 4/17/17), Pentair Clean and Clear Plus 320 sqft cartridge filter, TF-100 test kit
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Re: New pool sanity check - is my chlorine consumption high?
    Welcome to TFP!
    I would just stay with it and monitor it for now. Keep FC up and brush daily if you feel like it. When the FC dropped to 0 some algae probably started growing and used up your FC. The fact that Overnight Chlorine Loss Test is OK now is a good sign. You probably barely stayed ahead of it.
    Dec 2016
    Ft Lauderdale, FL
    2
    Thanks, will do
    One thing I couldn't find in my searching...what is considered a fail on an OCLT? Is it a 1ppm loss or greater? Or some % loss?
    DFW, TX
    24,974
    Yes, 1 or more. Here is a link to the full instruction, Overnight Chlorine Loss Test
