Thread: SLAM is complete ... what is the order to balance the rest
    Mar 2015
    Reading PA
    65
    Good Morning,
    SLAM is passed and complete. I need to raise CYA, salt, and TA - What order should I do this?
    My thoughts ...
    1 - add CYA to raise to 70
    2 - add salt to raise from 2200 to 3200/3400
    3 - allow FC to drop to 4-6
    4 - turn on SWG
    5 - adjust TA
    6 - adjust pH is necessary
    Numbers before SLAM were -
    pH 7.3
    FC - 0
    CC - 0
    TA - 30
    CYA - 30
    salt 2200
    current numbers -
    pH 7.3
    FC 12.5
    CC - 0
    TA 60
    CYA 30
    salt 2200
    Thanks!!
    18ft x 36ft 24500 gal vinyl liner inground
    Salt water pool - swim pure plus
    Hayward cartridge filter
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,091
    Re: SLAM is complete ... what is the order to balance the rest
    Yes to all that except your TA, it's fine at 60.
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    Jan 2017
    Monterrey, NL, Mexico
    490
    Go a little higher on you % on SWG and then you can come down from there.
    Looks good.
    Felipe
    7,500 gal Rectangular, Easytouch 8, Air+water temp sensors, Screenlogic2, IC40, intellibright5g color12v, Intelli pH, SD 70 filter w/Zeolit, Magicstream Laminars, waterfall. Raised Monolithic concrete lined with glass beads.
    In Sunny Monterrey,Mx!
