Results 1 to 11 of 11
Thread: Keeping FC up
    Apr 2017
    Houston
    182
    Keeping FC up
    So I have some algae, but I cant seem to keep the FC up. I'm probably not adding enough chlorine frequently enough, but with a higher CYA I'd expect levels to be higher.
    today:
    FC 2.4
    CC 0.2
    pH 8.0
    TA 100
    CH 270
    CYA 100
    CSI .29
    4/12
    FC 1.0
    CC 0.2
    ph 8
    TA 105
    CH 270
    CYA 90
    1) Should I add only 1/2 of the target 4 GAL of bleach, and the 2 qts of 28.3 MA or full amount of both bleach and MA?
    2) should I drain and fill to bring down CYA? I dont want there to be so much chlroine it's unpleasant to swim.
    45,000 gallon (18x49) in ground plaster in Houston. [Gallery]
    2HP Hayward Northstar Pump, Hayward DE 6020 (60sqft) filter, Pentair MasterTemp 400k BTU heater, Pentair SuperFlo 1HP -340038 water feature/fountain pump
    Pentair Easy Touch 8 w wireless remote, Hayward TigerShark QC, & Taylor 2006c
    40,863
    Re: Keeping FC up
    With algae you need to be following the slam process. That requires much higher FC levels. However with your high CYA it would make more sense to replace half the water before starting the slam.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    10,152
    Re: Keeping FC up
    4 gallons of bleach in a 45k gallon pool will not get you to SLAM level if that's what you're asking. I'd drain water to get your CYA to 60, then SLAM it.
    40,863
    Re: Keeping FC up
    I also just saw that it's been 2 weeks between your testing. To start the slam you need to be testing every 2 hours or so.
    Apr 2017
    Houston
    182
    Re: Keeping FC up
    Ive been brushing more frequently getting it before it's "thick" on the walls, so do I need to slam if I can keep the levels up?
    with a CC of .2 does that mean there's not much algae after brush and vacuum?
    40,863
    Re: Keeping FC up
    Any sign of algae means that you need to follow the slam process until you pass the three criteria to stop.
    Apr 2017
    Houston
    182
    Re: Keeping FC up
    OK. .
    Apr 2017
    Houston
    182
    Re: Keeping FC up
    So, when I drian the pool how much (really 1/2)?
    When I start SLAM ,I presume that will shut down the pool - no swimming.
    Will it get the algae in the photos?
    40,863
    Re: Keeping FC up
    You need to replace half the water. During the slam you need to brush the entire pool and two that will get rid of the algae.
    Apr 2017
    Houston
    182
    Re: Keeping FC up
    Another question, do I load up on chlorine, once balanced post slam, when I'm on holiday?
    no automated chlorinator.
    Or do I buy tablets?
    Am using TFP method now w bleach for chlorine
    40,863
    Re: Keeping FC up
    If your cya is not already too high many people do use tablets while on vacation. Although ideally you could get someone to swing by the house every few days and add bleach.
