Results 1 to 7 of 7
Thread: New swg ppol owner, pool cloudy blueish
    Apr 2017
    Silver Creek
    5
    We bought a new house with a 18x36 swg pool. It looks pretty good I guess, first test with tf100
    Fc 6
    Cc .5
    Ph 7.2
    Ta 130? If I did it right
    Cya 40
    Aqua rite says 3100 on salt, it's close, I had it checked at LPS last week.
    My ph was off the scale at over 8.6
    I added about 1/2 gallon muratic acid and got the pH down.
    First time doing any kind of test besides the simple 3 way test.
    Thanks guys.
    Terry
    Jun 2014
    17,333
    Re: New swg ppol owner, pool cloudy blueish
    Hello Terry and thanks for posting those results. Now based on the title of your thread, test results, and because your CYA is low (40) for a SWG pool, that might mean your pool is on the verge of an algae outbreak. It may have been struggling to maintain the proper FC, even though you currently tested FC at 6. What I would recommend is doing an overnight (OCLT) test. This could confirm if the FC dropped too low at some point to allow algae to start blooming. For today, you might consider adding some "regular/plain" bleach as well to bump-up the FC for today. Perhaps increase FC to about 10 for today. Then overnight do the OCLT and see if you pass. Of course if you fail the OCLT, you know you need to SLAM (link below). Maybe give your pool a good brushing today as well in case anything is trying to grow against the pool walls or bottom. Good luck and keep us posted.
    Pool School - Perform the Overnight FC Loss Test (OCLT)
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    9,273
    Terry,
    Welcome to TFP.. A Great resource for pool owners from any color creek...
    From your tests, I noticed that your pH is 7.2. Anything between 7.2 and 7.8 is fine, but most SWCG pools like to be on the 7.8 end.
    When your pH goes higher than 7.8, I suggest you only try to lower it to 7.6 or so. I find that my pool will often stay at 7.8 for several weeks, but will only stay at 7.2 for a few seconds..
    When you run the OCLT, make sure your SWCG is off or set to zero output.
    Apr 2017
    Silver Creek
    5
    Thanks for the input guys. I'll fiddle with it tonight.
    Apr 2017
    Silver Creek
    5
    Retested tonight.
    Fc is at 11 after running the swg at superchlorinate today.
    I think my ta is around 100
    This was before vacuumingthe pool this afternoon. We'll see what it looks like on the morning. I haven't done the oclt yet.
    But cc was less than .5 today.
    Sep 2016
    Melbourne, Australia
    29
    It's hard to tell from a photo, but that water looks good to me. It will be interesting to see what the OCLT shows.
    GQ
    ​GeoQuack
    Melbourne, Australia. Plaster pool 44,000 Litre (11,625 US gallons), 2 HP 1 speed pump, Zodiac LM3-40 SWG, Zodiac CX20 robotic cleaner, PoolSkim, solar heating, sand filter, clearchoicelabs.com.au test kit (TF100 or taylors not available in Australia), big eucalypt that drops infinate leaves, gum nuts, pollen and sticks into pool
    tdp's Avatar
    Sep 2015
    Suburban Philadelphia
    57
    My SWG pool was cloudy blue on opening last year and cleared up with just getting chemistry right and running the pump.
    ~17,500 gal. IG Fiberglass, Viking "Cambridge"; installed 6/2015
    SWG Hayward Turbo Cell T-9
    Hayward Hi-Rate Sand Filter
    Hayward Max-Flo XL pump
    TF-100 Test Kit/SpeedStir
