Thread: Circupool si45plus high salt reading
    Apr 2017
    Crawfordville fl
    3
    I have a circupool si45plus clorinator and meter reads 4400 ppm salt and high salt light flashing, but I have checked salt level with liquid test kit and digital tester and both read between 2800 and 2900 ppm is my cell bad?? Or what? All other readings are within guidelines..and have cleaned cell plenty of times never any buildup....
    Vinyl liner in ground approx.17000 gallons circupool si45plus salt system
    Jun 2011
    Long Beach, CA
    2,889
    Re: Circupool si45plus high salt reading
    Welcome to TFP!
    Check the system status and the 9th option should be the cell size and it should match the 45 cell size. A wrong sized cell option can cause this type of error. Usually a bad cell will measure a lower salinity level, not higher.
    Apr 2017
    Crawfordville fl
    3
    Thank you I will check
    Apr 2017
    Crawfordville fl
    3
    Thank you ping I checked when I got home also talked to tech support at discount salt pool where I bought the unit and they said same thing you did, And guess what it was wrong should have been set to C9 cell and it wasn't I set it to C9 and still have high salt light flashing but I will wait and see if it resets in awhile...I hope so.....lol
    Jun 2014
    Roseville, CA
    359
    I was going to suggest what you did... BTW, my SI30+ is set at C9, BTW.
    IMO your salt is a bit low. It seems to be a bit finicky, even going so far is to ask for a -01 to +.01 CSI number... Is that even possible?
    SWG: CircuPool (5/2018) Universal 40; 3000ppm seems ideal;
    My Ideal Specs:
    FC 5; PH 7.4-7.6; TA 90; CH 350; CYA 75; = SI ~ 0.19
    14,000 gal, in ground, plaster, Cartridge filter, Borates
    TAYLOR K - 2006 Last Circupool SI30+ 4 years RIP.
