Thread: Pool Leak? New Pool
    Jun 2016
    Fontana, CA
    99
    Pool Leak? New Pool
    Looking for some help to see if I have a leak in my pool.
    Bucket test was conducted and over a 36 hours the bucket dropped 11CM and the Pool water dropped 25CM so a difference of 14 CM is this normal?
    I have noticed about .75 of an inch per day even with overcast 70-80 degree weather since pool was plastered a month ago. I have turned off all the sheers and spillways including the pumps during this time.
    Thanks for any insight.
    blakeusa's Avatar
    Jul 2010
    Ashford, CT
    572
    Re: Pool Leak? New Pool
    Do you get any air in the pump basket or air bubbles in the returns into the pool ?
    I would expect the water level in the bucket and pool to be about the same (evaporation rate).
    3/4 inches a day seems like a lot to me... meaning in one week you would loose 5+ inches of water.... ?
    or 10 inches over two weeks time...
    What does your builder say?
    25k 20x40 Gunite w/ integrated Spa & Caribbean Blue Plaster, Curved Bluestone Coping, Deck Jets
    Pentair Easy Touch/Wireless, Sta-Rite Intellipro SRVS Pump, Intellibrite Lights, & Pentair IC40 Cell, Sta-Rite 450sf Cartridge filter
    Heated from Central Boiler - Outdoor Wood Furnace & Triangle Tube Max Heat Exchanger
    ColorQ Pro
    TF-100
    40,881
    Ideally you want the bucket nearly fully submerge in the water (like sitting on a step) and nearly full so that the bucket and pool see the same wind, etc that will impact the evaporation.
    If there was no leak and the bucket was properly set up, the bucket and pool would have dropped the same amount due to evaporation ... so seems like you have a leak
    Jun 2016
    Fontana, CA
    99
    Thanks for the tips. I had done my own test, then the pb came out to do his own test.. same result.
    Bucket and pool are not evaporating at the same level.
    Hope they can find a fix
    Jun 2016
    Fontana, CA
    99
    Quote Originally Posted by blakeusa View Post
    No bubbles once the system gets primed.
    Yes, feel it is excessive about 3-4 inches every 4 days before i add water since water level gets close to the plaster.
    Waiti g to talk to the owner tomorrow. Initial finding by the project manager was no leak..
    Jun 2016
    Fontana, CA
    99
    Spoke to the owner today and his guy told him no leak.. So he will have him retest when I'm present..
