Thread: La Roche Posay thermal pool
    Apr 2017
    FORT DE FRANCE
    2
    Smile La Roche Posay thermal pool
    Dear FTP friends,
    I have severe psoriasis and I project to buy a small pool because I really need to soak all my body in water with a high concentration of magnesium to reduce all the itchy plaques on my body.
    So I have planned to buy :
    - a small ABG intex pool (1189 US Gallons )
    - a 3 kW intex pool heater
    As I would like to “simulate” the magnesium concentration of La Roche-Posay à french thermal spring water well known for its curative use.
    In order to have the targeted magnesium concentration (about 4.4 mg/L), I would have to add about 335 lbs of Magnesium chloride hexahydrate (MgCl2*6H2O).
    I will add borax at 50ppm for extra water softening and will sanitize with bromine.
    I know that this high salt concentration would be harmfull for the heater, so I will carry out a special routine to rinse the heater once a week with fresh water.
    Do you think this project may be realistic ?
    Many thanks for you cooperation
    I am a newbie, planning to buy a pool... nedd your advices
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Re: La Roche Posay thermal pool
    Welcome to TFP!
    Interesting, I did not know Intex made an electric heater. I could not find what material the heat exchanger is made of, but they say it is OK to use with their saltwater system so that is a good sign. Apparently, it is not available for sale in the US. That set up should work fine.
