Thread: Minimum CYA to slam?
    tdp's Avatar
    Sep 2015
    Suburban Philadelphia
    57
    Question Minimum CYA to slam?
    Pool just opened today; readings are
    (Water mostly clear, not green, but a lot of dirt/debris with what looks like a small amount of algae on one seat. Pool was closed in Oct.)
    water temp 56F
    FC 1.5
    CC 5.5
    TA 70
    Ca++ 150
    CYA 0 (I let water sample for CYA test warm up on top of a running clothes dryer so it was warmer)
    Salt 2400
    pH ~7.3-ish
    Questions:
    1) I clearly need to slam; what is the minimum CYA for a slam?
    (I will need to get the CYA up to ~70 eventually for SWG, but assume I can get by with much less while slamming, then raise CYA after, since higher CYA=more chlorine for slam?)
    2) in what order should I slam and adjust the other chemistries?
    Thanks!
    ~17,500 gal. IG Fiberglass, Viking "Cambridge"; installed 6/2015
    SWG Hayward Turbo Cell T-9
    Hayward Hi-Rate Sand Filter
    Hayward Max-Flo XL pump
    TF-100 Test Kit/SpeedStir
    Donldson's Avatar
    NW Ohio
    3,219
    Re: Minimum CYA to slam?
    Your CC level tells me there is a problem that needs to be corrected before you add CYA. Follow these steps before adding CYA to your pool:
    Dose chlorine up to 10 ppm FC.
    Retest FC and CC after 10 minutes.
    If FC is less than 5 upon retest repeat above
    Once you get an FC reading above 5 (could be right away, could take a few rounds) then you can add 30 ppm CYA and begin your SLAM. Once you complete your SLAM you can increase your CYA to the correct level for SWG use and settle in to your normal routine.
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath
    tdp's Avatar
    Sep 2015
    57
    Okay, I dosed up to 10 FC and it was 6.5 after about 20 mins. So I will add CYA tonight and start slam tomorrow.
    Donldson's Avatar
    NW Ohio
    3,219
    Glad to hear. I would bump it back up to 10 for the overnight, since your pH is already fine there's no reason not to keep the FC level up and get a jump on the SLAM.
