Results 1 to 7 of 7
Thread: New hot tub,best way to level and set up
    MoodyMaMa's Avatar
    May 2015
    Kamiah Idaho
    24
    Just got my hot tub delivered today! I was so excited; then they said they could not place it where we want because it is not level enough and the tub would eventually crack. One store we asked they said they could put some planks under the tub and level it that way and it would work so I didn't think to ask this store when we finally chose. So now I am sitting here with an empty spa.
    I will attemp to post a picture of the spot it is going. On the yard side of the crack on the cement it gradually sloped down till at the edge it is two inches lower than at the crack. What's the best way to deal with This?IMG_2288.jpg
    Then since he tub was just built within the last two weeks do I really need to use the ahhsome?
    This is a bull frog R-7L says water capacity 426 gallons.
    bullfrog hot tub R7L 425 gallons
    With an Ozonator
    Using the Chlorine system
    Test kit is Taylor K-20006
    Nov 2015
    VT
    87
    Re: New hot tub,best way to level and set up
    Yes on the Ahhsome.
    You could take your chances by skipping it but if you start wondering why you can't keep your water balanced/sanitary then you'll know why.
    As far as leveling...
    - You could pour new level concrete over the existing.
    - You could box in an area with pressure-treated lumber where the tub will sit and fill that box with gravel or small stone and screed/rake that level. That's what I have.
    - You could put down some planks and shim them level. It would also make a nice place for varmints to nest under your warm tub.
    There may be other solutions but that's all I've got right now.
    The delivery guys did the right thing. Some might have "dumped and run".
    Hot Springs Sovereign (1999?)
    MoodyMaMa's Avatar
    May 2015
    Kamiah Idaho
    24
    Thank you my husband says he wants to go the concrete route (I was hoping for something faster��) So hopefully this weekend.
    With using the Ahhsome I have to fill the tub all the way up, do I need to get it up to the right temperature or balance chemicals any? Or do I just fill, add the ahhsome, run for awhile and dump?
    With an Ozonator
    Nov 2015
    VT
    87
    I don't think temp. or balance matters for the Ahhsome treatment.
    Jul 2016
    Vero Beach, Florida
    74
    Quote Originally Posted by Brian VT View Post
    Ahh-Some will be effective even if the water is not balanced prior to the plumbing colonoscopy. However, it will work faster and be slightly more effective if the water is warmer or heated up to 100-104 degrees.
    MoodyMaMa's Avatar
    May 2015
    Kamiah Idaho
    24
    How about th filters? Brand new o should I leave them in during the initial cleanse or remove?
    With an Ozonator
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    No need to leave them in when they are new.
