Results 1 to 12 of 12
Thread: Bleach
    Apr 2017
    marlton/nj
    23
    Bleach
    I have to turn off my swg for 2 weeks while I try scale tec to remove scale(described in another thread). instead of using chlorine tabs, I was going to use bleach. is there anything I need to know before I do this? do I just use the Clorox I have in the laundry room? or is that not the correct stuff? I will use the pool math chart on this site for values.
    also, if anyone knows....im using a jandy aquapure swg and its connected to an aqualink control panel. I don't see anywhere to turn the swg "off" as that's part of the directions on the scale tec label. is turning output down to 0% the equivalent to being considered "off"?
    thanks in advance
    anthony
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    9,318
    Re: Bleach
    Anthony,
    Yes, turning the SWCG's output to zero is the same as turning it off...
    yes, plain bleach, no scented or splash-less bleach..
    Apr 2017
    marlton/nj
    23
    Re: Bleach
    thanks for the reply. I went to lowes to pick up bleach. I wanted to get Clorox but they only had splashless so I got an off brand. I have to keep pool at 1.5-2 fc. I will try to keep as close as possible to high end. should I be calculating this as 8.25% or 7.86%? not that it will make a huge difference but I have slight ocd.
    thanks
    Anthony
    domct203's Avatar
    Jun 2015
    CT
    3,913
    Re: Bleach
    That is 8.25 % bleach.
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Bleach
    That's the stuff you want. The only other thing that matters besides it being just plain old bleach is the "born on" date. Bleach degrades over time so the fresher the better. Not as critical for household (8.25%) bleach but still important. Chlorine Date Code Decoder/Easy Way to Measure Strength.
    Isolated Spa - 345 Gallons
    Apr 2017
    marlton/nj
    23
    Re: Bleach
    thanks guys.
    40,893
    Re: Bleach
    I would warn you that a FC of 1.5-2ppm is too low (really even for a SWG pool).
    What is your CYA?
    Use the FC/CYA Chart and use the non-SWG table while your SWG is out of commission.
    Apr 2017
    marlton/nj
    23
    Re: Bleach
    What is your CYA?
    I know it is. cya is 65-70. the product im using "scale tec" suggest 1.5 -2 chlorine level or the chlorine will render product ineffective. they suggest using algaecide while using product. believe me, I don't feel good about it but I feel worse about the scaling.
    40,893
    Re: Bleach
    Ah, understood. Although I put little faith in potions like that
    Apr 2017
    marlton/nj
    23
    Re: Bleach
    I hear ya but I don't have a whole lot of choices. figured Id throw $80 at it, and hope for a miracle that relieves me from scrubbing entire filled pool with a pumice stone. with that said, the scale is much better than it was, most likely due to me holding ph 7.0-7.2. just put the scale tec in Saturday morning so hoping that finishes it up.
    Mar 2017
    Rocklin/CA
    20
    Re: Bleach
    What do y'all prefer using between the box store bleaches vs. the HASA bleach? I see the Clorox 8.3% stuff at Costco going for $8.89 for 3 gallons & the 12.5% HASA stuff for $17.xx for the 4-pack.
    17k gal IG, 3/4 HP Hayward pumps, C3000 cartridge filter, H400ID heater, Polaris 36 Pool Sweep, K-2006 test kit
    40,893
    Re: Bleach
    Use whatever is cheapest for the amount of chlorine that you get. There are a few calculators within the Forum that will do the math for you.
