Thread: Quick TA, Ph question
    ka8yiu's Avatar
    Aug 2016
    SW FL
    165
    Let's see if I'm following this:
    Raise TA: add baking soda
    Raise Ph: add borax
    Lower TA and Ph: add acid
    Raise Ph, lower TA: aerate
    8K gal IG Fiberglass (San Juan Waikiki I)
    TF-100 Testing Kit
    Hayward Max-Flo VS Pump
    Hayward Star Clear Plus Cartridge Filter
    Pentair Model 320 Automatic Chlorine/Bromine In-Line Feeder
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,892
    Re: Quick TA, Ph question
    Quote Originally Posted by ka8yiu View Post
    Aeration raises pH with TA remaining steady
    Support the site
    Donldson's Avatar
    NW Ohio
    3,211
    You have a tablet feeder in your signature, if you are using that you may need to include:
    Raise pH and TA: add Sodium Carbonate (aka soda ash or washing soda)
    Since pucks are highly acidic using them often requires raising both pH and TA regularly.
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath
    May 2014
    Franklin, NC
    9,892
    Quote Originally Posted by Donldson View Post
    Oops, missed the tab feeder.
    Time to retire that bad boy!
    Support the site
    ka8yiu's Avatar
    Aug 2016
    SW FL
    165
    I thought aeration did as said above, but I saw a post contradicting that. Just making sure.
    The tab feeder is only used if I need to raise CYA. I keep it toward the lower end so it is useful if I plan to be out of town.
    Tnx
    TF-100 Testing Kit
