Thread: DPD Test Powder turned to granules
    Aug 2013
    Hilton Head, SC
    133
    My DPD test powder, R-0870, turned to granules over the winter, even though the entire TFT test kit was indoors, air conditioned & heated. Is it still usable?
    thx
    ed
    4k, IG, Gunnite, Jandy Valve, 1HP Haywood, 2" flow, single 2" line for skimming & vacuum, Pentair FNSP 36 DE w/125 GPM Multiport 50 PSI, TF-100 Test Kit, built 1991, Hilton Head, SC
    Jun 2014
    17,343
    Re: DPD Test Powder turned to granules
    It should be okay Ed. Simply tap/crush the granules into a fine powder and you should be fine.
    30,962
    If, when you test, the pool sample turns pink, the R-0870 is good.
    Oct 2016
    Phoenix
    203
    My old R-0870 got granular over the winter and I compared it to the new batch I just got from the TFT spring sale. Same results.
    Dave in Phoenix, AZ, USA
    12,000 gallon IG (5' max depth) , Pebble-tec,
    Hayward SP2303 Maxflo 1.65 HP, Triton TR60 sand filter, 1 skimmer, Pool Devil skimmer, 3 returns, 1 aerator port, Navigator suction-side sweep, Hayward valve actuator, Rainbird sprinkler timer used for valve automation and chlorine injection. Softened water used for makeup.
