Thread: Replacing Pool Light gaskets - install dry or ?
    Jan 2017
    Orlando/FL
    124
    My replacement light bulbs have arrived for my old Pentair SAM Amerilite lights. I have new gaskets. One of the light leaked and was half full of pool water. I want to be sure it doesn't leak again.
    I will install the new gasket around the lens dry, but should I put anything between the rubber gasket face and the metal lip of the light fixture (like a thin coating of pool o-ring lube or silicone) to help the gasket seal - or just install dry as the directions state?
    20K gal In-ground pool with raised Spa overflowing into pool; two Jandy Sheer Descent waterfalls; Pentair IntelliTouch i7+3, IntelliChlor, IntelliPH, 3 SAM/SAL lights, Pentair FNS60Plus filter, two 1.0 HP WhiperFlow pumps, Jandy/Compool auto-valves, RayPak Heatpump, RayPak 406A LP spa heater, Polaris 360 PS Cleaner. Patio and deck lighting by Volt; Volt 600W landscaping transformer; Webber grilling station
    Jan 2017
    Orlando/FL
    124
    Re: Replacing Pool Light gaskets - install dry or ?
    Bump
    Any thoughts on this? Replacement light bulbs have arrived. I'll be finishing this project tonight. Should I install the new gasket dry or use something extra to help the sealing?
    Maybe I'm over thinking this.
    Apr 2016
    Orlando FL
    48
    To update my post - I installed both SAM lights dry. With new Pentair gaskets. The lights where just sitting in the pool (not mounted in niche) to test bulbs. I pulled them out about two days later and both had a little water in them.
    So this time I ran a bead of silicone around the housing where the gasket sits (as shown in photo). I hope this works. Putting it together dry with a new gasket didn't work. I tightened the spring clamp according to Pentair's direction.
    Not much else one can do.
    20K gal In-ground pool w/spa; IntelliControl, IntelliChlor, IntelliPH (Acid-Injector), SAM/SAL lights, Pentair FNS60Plus filter, two 1.0 HP WhiperFlow pumps, Jandy/Compool auto-valves, RayPak Heatpump, Jandy Gas heater
    Jun 2014
    17,333
    I noticed you were all alone on this thread. How did that replacement work out for you?
